Results 16 to 30 of 31
Thread: Battery Tender '06 R1200GS
  1. #16
    Geek jlevee's Avatar
    Feb 2006
    Phoenix, AZ
    Accessory Socket Charging
    When I got my 1150 I used the accessory socket to charge (its an 04) I thought it was the best idea ever. However now it wont charge through the socket & I had thought maybe my tender had issues, so I borrowed one from a friend, turns out it wont charge through the socket either. Not sure if it is the socket itself or something else in the system yet. In talking to my dealership they said BMW no longer recommends using the accessory socket for charging, so i use pigtails on it & the RT.
  2. #17
    Registered User waxrash's Avatar
    Jul 2011
    Garner, NC
    Battery Tender
    The 1150 is not CANBUS.
    Lynn
    2008 BMW R1200RT (most fun you can legally have)
    2002 BMW R1150RT
    2008 Kawasaki Versys
  3. #18
    Jul 2011
    Garner, NC
    Battery Tender
    Quote Originally Posted by bobframe View Post
    Does it take a "special" charger such as the Optimate to charge through the accesory plugs? That is, does the CAN-bus system dictate a unique charging technology?
    The answer is yes. The charger must be canbus aware and send a signal to open the circuit before charging begins. Thus "smart". A regular charger will not work thru a factory CANBUS port.
    Lynn
    2002 BMW R1150RT
  4. #19
    Jul 2011
    Garner, NC
    Battery Tender
    I contend that nothing is more simple than a canbus charger plugged into any factory socket. Look ma no wires. It ain't cheaper though. With my RT $50 is nothing, so I took the easy route. Of course that was after taking the other route. Luckily I needed a second charger anyway for another bike.
    Lynn
    2002 BMW R1150RT
  5. #20
    Jul 2011
    Garner, NC
    Lynn
    2002 BMW R1150RT
  6. #21
    Riding where it's hot! AZ-J's Avatar
    Mar 2007
    Scottsdale, AZ
    Battery Tender works fine on BMW batteries and the new Shorai LIPE battery. I know both from experience.
    But if you have a B T older than 2007 (which is the year I got mine) Deltran will trade you up for a lower fee than new.
    My bike shown here
    Jordan M, MOA #24434
    My Blog
  7. #22
    Jul 2011
    Garner, NC
    Battery Tender
    According to this:
    http://batterytender.com/resources/i...batteries.htm/
    Gel batteries (BMW) charge at a lower voltage. And it looks like they still sell a separate gel charger.
    http://www.batterymart.com/p-battery...y-charger.html
    I'm just not smart enough. So I just bought the BT gel version for the 1150 and the optimate for the 1200.
    Does it matter? Probably like the oil debates.
    Lynn
    2002 BMW R1150RT
  8. #23
    Urbana, IL
    I believe the gel charger is supposed to charge float at 13.4 volts and the agm battery at 13.6 volts. I think there is more variation in other areas like quality control on the battery manufacturing as to whether it matters one whit or not.
    As to the special charger for the acc jack, i have used a BT thru that port successfully. I have always turned the key on and then off and the port stayed on until the charger went to float and beyond. Although i have seen variable behavior with that port with different model years. Sometimes it seemed that you did not have to cycle the ign key.
    My other bike is a BMW.
  9. #24
    Registered User b25bsaboy's Avatar
    Aug 2010
    Calgary, AB. Canada
    Quote Originally Posted by milo View Post
    Battery Tender Junior works well and is usually under $30.
    1+
    Rick MacPherson
    Success is Not a Destination, But a Journey.
    Accredited Motorcycle Appraiser
    1968 BSA Starfire, 1976 BMW R75/6, 1992 R100RT, 2009 R1200RT
  10. #25
    Mar 2007
    Scottsdale, AZ
    The Battery Tender I have is good for up to 14.7 Volts.
    My bike shown here
    My Blog
  11. #26
    Jul 2011
    Garner, NC
    Battery Tender
    From the battery tender website on gel batteries: " The recharge voltages on this type of cell are lower than the other styles of lead acid battery. This is probably the most sensitive cell in terms of adverse reactions to over-voltage charging. "
    Probably why they sell the gel version with the lower charge voltage.
    If the regular charger "works fine" why would they do that?
    Lynn
    2002 BMW R1150RT
  12. #27
    Jul 2011
    Garner, NC
    Battery Tender
    From battery stuff.com: "If the incorrect battery charger is used on a Gel Cell battery poor performance and premature failure is certain"
    Are they all making this up?
    I don't care what you guys use, I'm just verifying what I remember when I ordered mine.
    Lynn
    2002 BMW R1150RT
  13. #28
    Jul 2011
    Garner, NC
    Battery Tender
    Interesting reading here.
    The deltran engineer says buy a gel specific charger.
    http://www.advrider.com/forums/showt...=660892&page=3
    Read Post #36
    Good enough for me.
    Lynn
    2002 BMW R1150RT
  14. #29
    Registered User f14rio's Avatar
    mattituck new york
    i wonder which threads tend to be longer
    battery ones or oil ones. oh yeah, winter storage ones.
    also, it occurs to me that if you use a battery charger all the time you might have a battery that won't hold a charge very well and you might not know it.
    no problem...just sayin'
    "Enemy fighters at 2 o'clock!...Roger, What should i do until then?"
    2010 r1200r, 2009 harley crossbones, 2008 triumph/sidecar, 1970 norton commando 750
  15. #30
    Old man in the mountains osbornk's Avatar
    Feb 2006
    Marion VA-In the middle of some of the best riding in the country.
    Quote Originally Posted by lbarbee View Post
    from the battery tender website on gel batteries: " the recharge voltages on this type of cell are lower than the other styles of lead acid battery. This is probably the most sensitive cell in terms of adverse reactions to over-voltage charging. "
    probably why they sell the gel version with the lower charge voltage.
    more money
    'You can say what you want about the South, but I almost never hear of anyone wanting to retire to the North.
