Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: Battery Tender '06 R1200GS
    Registered User bobframe's Avatar
    Jan 2013
    Northeast GA
    I need a "smart" battery charger for my '06 GS that I can leave plugged up to the bike whenever its stored and not worry about damage to either bike or battery. I've had great luck with a Battery Tender on my ST1300, but am concerned about the BMW electrical system. I'm sure BMW sells one, but I'd like to find one that is closer and cheaper.
    Suggestions?
    Many thanks,
    Bob
    Last edited by deilenberger; 01-28-2013 at 07:52 PM. Reason: added year/model to title
    Registered User waxrash's Avatar
    Jul 2011
    Garner, NC
    Battery Tender
    Lynn
    2008 BMW R1200RT (most fun you can legally have)
    2002 BMW R1150RT
    2008 Kawasaki Versys
    Mar 2004
    Northern WV
    Battery Tender Junior works well and is usually under $30.
    14 R1200GSA, 93 R100R, 15 FJ-09, 15 RK, WR250R No car is as fun to drive as any motorcycle is to ride.
    Mar 2008
    DeLand Florida
    I second the Battery Tender, or even the full size one. I have used them for many years with no problems. As soon as I get home I connect it and forget it using a fused pigtail.
    Wayne
    Jul 2011
    Garner, NC
    Battery Tender
    I have all 3. Problem with the junior is it won't charge if battery is very low, say if owner left something on and killed the battery. Full size battery tender works well also. I use mine on my 1150. Optimate will charge thru the canbus power ports and has additional features to de-sulphate (sp?) the battery. All three will maintain well. I use jr on the versys, full size bt on the 1150, and optimate on the canbus rt. in my opinion, worth the extra $50, but all will work. My dealer sells the optimate if that means anything.
    Lynn
    2002 BMW R1150RT
    Jul 2011
    Garner, NC
    Battery Tender
    I am not a battery expert, but when I bought my full size BT I was instructed to get one for a gel cell battery which charges slightly different. New ones may be switchable but not when I purchased.
    Lynn
    2002 BMW R1150RT
    Jul 2011
    Garner, NC
    Battery Tender
    Btw, OP said "smart"
    Lynn
    2002 BMW R1150RT
    Old man in the mountains osbornk's Avatar
    Feb 2006
    Marion VA-In the middle of some of the best riding in the country.
    Quote Originally Posted by milo View Post
    I agree. I've had 2 for years. Found them on sale at Motorcycle Superstore for $19.95 each.
    'You can say what you want about the South, but I almost never hear of anyone wanting to retire to the North.
    Norm Norms 427's Avatar
    Nov 2011
    Spokane, WA
    I use Sears smart charger/monitors for about $30 wired directly to the battery terminals.
    BTW, I'd recommend using a christmas tree light timer so that you can program the charger/monitor to come on only about an hour each day ... 24/7 is overkill.
    Now: '12 R1200RT Midnight Blue Metallic / '11 Ural Patrol 2WD ridden to Alaska / '09 KLR 650 / '05 HD Heritage Softail / '08 Harley Sportster 1200C / '85 Yamaha VMax bought new. I wasn't ready to say goodbye: www.shaunlunt.typepad.com
    Jan 2013
    Northeast GA
    Quote Originally Posted by Norms 427 View Post
    But isn't this what the "smart" charger is all about? Thought it could "read" the battery and only apply what charging was needed....thus allowing a lazy owner, such as myself, to plug it up and then fully ignore the whole thing. I have used such a charger on my Honda and left it unattended for weeks at a time with no ill effects.
    I would connect the charger directly to the battery, so using an accessory port is of little benefit to me.
    Jul 2011
    Garner, NC
    Battery Tender
    Quote Originally Posted by bobframe View Post
    Works either way. I said the same but ultimately found the accessory port easier and with less clutter.
    Lynn
    2002 BMW R1150RT
    Jan 2013
    Northeast GA
    Quote Originally Posted by lbarbee View Post
    Actually, the more I pondered this, the more I like the idea of connecting a battery tender straight into one of these powerlet outlets. Do I have this right? IOW, add a powerlet adapter to the SAE connection on the Battery tender and plug straight into the accessory outlet? If so, this is more elegant than having to connect leads to the battery and fish the cable out to where I can attach it to tender leads.
    We don't take a trip...the trip takes us.
    2016 BMW R1200GSA
    2012 Honda XR650L
    Jul 2011
    Garner, NC
    Battery Tender
    Tecmate comes with powerlet male and clips and sae. You have your choice.
    Lynn
    2002 BMW R1150RT
    Jan 2013
    Northeast GA
    Does it take a "special" charger such as the Optimate to charge through the accesory plugs? That is, does the CAN-bus system dictate a unique charging technology?
    2016 BMW R1200GSA
    2012 Honda XR650L
    Urbana, IL
    There has been a lot of discussion about this since the accessory socket was connected to the ZFE in about 2005...but I think the answer is no. Connecting any charger to the socket will keep the circuit on until the charger goes to float and then it may or may not switch off. It's a lot simpler to connect a pigtail to the battery and be done with it.
    My other bike is a BMW.
