Results 1 to 15 of 20
Thread: '06 1200GS Accessory plug?
    Registered User bobframe's Avatar
    Jan 2013
    Northeast GA
    Noob here.
    Does my GS have an accessory plug somewhere? I'm looking for an easy way to connect a Garmin Zumo 550. I plan to eventually add a fuseblock but if there's a simple plug and play solution that may be a good interim solution.
    Many thanks,
    Bob
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    You have two plugs. One is the standard Powerlet style plug on the left side of the bike just under the riders portion of the saddle.
    The second one is a special socket wrapped up and hidden by the front forks on the left side your bike. It is intended for GPS power. You need to buy and wire the appropriate plug from BMW. I'm sure someone will have the part number.
    Jan 2013
    Northeast GA
    Are these outlets switched or constant?
    We don't take a trip...the trip takes us.
    2006 BMW R1200GS
    2008 BMW R1200RT
    Jun 2008
    SF Bay Area
    Switched, but... they stay on for "up to 15 minutes" after you turn off the ignition. I haven't a clue what triggers the "up to 15 minutes" part. Most of the time the socket turns off about 1 minute after turning off the ignition. One other note... not an issue for a GPS but the total draw from the accessory sockets is capped at about 5 amps on the GS. Draw more than that and the bike will turn the socket off. Next time you start the bike the socket will be re-enabled. The bike may re-enable the socket before you restart the bike.
    Jan 2013
    Northeast GA
    So, using these for heated gear is out. Glad I asked. But might make a good choice for a GPS....still, I think I'd prefer to hardwire the GPS into a fuseblock.
    Can I use one of the powerlet outlets to connect a Battery Tender?
    2006 BMW R1200GS
    2008 BMW R1200RT
    Urbana, IL
    You have two plugs.
    http://www.maxbmwmotorcycles.com/fic...T_61%201%20656
    My other bike is a BMW.
    Urbana, IL
    Quote Originally Posted by bobframe View Post
    I would wire the fuzeblock to the battery for a source and the parking light circuit makes a good switched source to turn on the fuzeblock switched circuits.
    Jan 2013
    Northeast GA
    Quote Originally Posted by cjack View Post
    Where can I find this circuit? What color wire am I looking for?
    2006 BMW R1200GS
    2008 BMW R1200RT
    Urbana, IL
    The parking light is with the headlight...a rubber plug with a small bulb. Turn the key on and it will light up. The wire for it is gray/black and the ground return for it is brown.
    Apr 2007
    Tampa, FL
    You can also tap the accessory plug for the fuse block relay. Closer to the fuse block if you mount it under the seat for an easier wire run. Eather works well. See other current thread, same subject for pics.
    Urbana, IL
    Quote Originally Posted by dwestly View Post
    However, the accessory socket does not turn off with the key for at least a minute or so. If you have a couple of fog lights connected thru the Fuzeblock, then they will continue to consume battery until the accessory jack turns off.
    Apr 2007
    Tampa, FL
    Mine turns off in about 30 seconds...
    Jan 2013
    Northeast GA
    Regarding the second one...On my bike there is an accessory port mounted on the horizontal surface of the plastic panel to the left of the gas tank/front forks. Is this an OEM accessory port? Picture shown below.
    2006 BMW R1200GS
    2008 BMW R1200RT
    Urbana, IL
    That is OEM on the Adventurer.
    Jan 2013
    Northeast GA
    Any chance that the OEM configuration is to run this straight to the battery? I have something wired into the battery (there are a second set of wires connected to the + and - batt terminals) and they are wrapped in the same black plastic wrap as the wires are that terminate in this accessory port. I was hoping that these were added on as a means of bypassing the CAN-bus system and allowing one to connect a battery charger straight to battery.
    2006 BMW R1200GS
    2008 BMW R1200RT
