Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: 2007 RT Final Drive Bearing Replacement
  1. #16
    Quote Originally Posted by Jankoman View Post
    Here is the plate bolted to flange with 5/8شاط nuts as spacers. The 8شاط gear puller is mounted on top, grabbing the plate. I heated flange with Benzo-matic torch: took about 12 minutes to get to a temperature where the flange began to move. Once it started moving, it came right off. Now having the proper T40 bit, I would have removed the caliper prior to this step.
    Attachment 37257
    Another method that can be used to pull the flange is to use a harmonic balancer puller attached to a slide hammer. Mine came as part of a cheap ($12) slide hammer kit. It attached to the flange using three of the wheel lug screws. As you noted it doesn't take much to pull the flange once it is heated. A few gentle taps with the slide hammer did the trick.
  2. #17
    Sep 2009
    Chestnut Hill, MA
    No differences between old BMW bearing and new NSK bearing. I used calipers to measure OD, ID and thickness.
    Attachment 37263
    I am certainly not a mechanical person, and am very impressed with your construction of tools, photography, & perseverance but as noted in my quotation from one of your steps, if there is no difference between the "old BMW bearing and new NSK bearing" what is the point? I think the purpose of your work was to replace that bearing, wasn't it?
    John Gamel
    2015 Ebony Metallic R1200RT
    BMW CCA 2006 - Present; BMW MOA 2009-Present
    Walt Kelly: "We have met the enemy, and he is us."
  3. #18
    R1200RT jankoman's Avatar
    Apr 2009
    Ulster Park, NY
    Quote Originally Posted by ExGMan View Post
    I understand. From a dimensional standpoint there were no differences. The outside diameter (OD), the inside diameter (ID) and the thickness were the same. The BMW bearing was bad: the roller balls sealed between the two races were not smooth and there was play between the races. Again, someone might ask if there are any dimensional differences between the two manufacturer's, and there were none. Had I bought a replacement bearing from a BMW dealer, the dimensions would not be of concern. But, because I bought an aftermarket bearing, I would want to know if the aftermarket bearing is the same as the BMW bearing. And it was, down to a thousandth of an inch. The only difference, one might argue, is the quality. Time will tell, but my guess is that the NSK is of better quality.
    "To make something simple is a thousand times more difficult than to make something complex." MK
  4. #19
    Apr 2009
    Ulster Park, NY
    Agreed! I was expecting to have to apply alot of force to slide flange off. However, the heat was key. After about 10 minutes I could start to hear the flange expanding then off she slid a couple of minutes later. Sliding it back on went even smoother: I had wrapped the flange in foil and put in oven at 200 degrees for about a 1/2 hour, she dropped right back on!
  5. #20
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Apr 2008
    Calgary AB
    Thumbs up
    Impressive write-up and pictures. Takes some (much) of the mystery out of the 'hidden' parts of the drive train. Even if I never do this repair on one of our RTs it is good to know what the mechanic is doing should there be any issue with the repair, cost, or parts required. Information like this is very helpful. Thanks.
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
  6. #21
    fd 2006 1200rt
    Would like to borrow or buy or rent tools
    psi1990@yahoo.com
  7. #22
    Kindly curmudgeon W7lej1's Avatar
    Aug 2006
    Spokane Valley, WA
    Well, I'm impressed!
    EXCELLENT write-up and photos. Thank you!
    Regards, Marty
    Marty in Spokane Valley, WA
    '79 R65 - the rolling running project bike
    '08 R12RT - "new scoot"
