Results 1 to 12 of 12
Thread: 03 RT Heated grip question
    Hi all,
    The right heated grip has cracked and I can see a gold material under it. It seems to heat fine but I'd like to change the grips. Do you need to buy the full heated grip assembly from BMW or is the heating element under the grips?
    Thanks,
    Jon
    Maryland
    Try looking here for what you want. I believe this is just the outer grip.
    http://beemershop.com/Merchant5/merc...uct_Code=HGRPL
    2004 R1150RT 171,200 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 406,800 BMW miles
    AMA,BMWRA,BMWMOA
    Quote Originally Posted by kioolt View Post
    Thanks, So does this mean that the heating element is under the grips?
    On the Road
    Aug 2012
    Northern California
    heated grips
    Yes
    John
    thanks for the link. i knew they existed, but could not recall who had them available. they seem to be a hard-to-find item. now i can get rid of the gummy 12 y.o. ones on my bike.
    Apr 2007
    Nacogdoches, TX
    Be gentle when removing the old ones. The heating element is a bit fragile.
    Compressed air works well to release them from the element.
    '08 BMW R1200RT
    '75 Red R75/6
    Boxer, paint shaker redbeemer's Avatar
    Nov 2004
    Winston, OR
    One sixtieth the cost!
    Beats the $1200 quote that I got for doing this fix!
    The fine wires are what makes them a bear to change out so its easier[faster/more profit] to replace the whole grip assembly.
    Cat Televangelist; "and Morris brought down from the sofa the 10 entitlements!"
    May 2008
    Adirondaks and LI,NY
    Yikes! $1200? What does a tire change cost?
    Jan 2009
    Hillsborough NC
    link to heated grip over element replacement
    It seems there are two types of heated grips. Some have the orange gold wrap, some have a more rubber welded version. I have linked a thread that has both shown in it. My 03 KRS had the rubber molded together and seems far more difficult to remove. Also have to watch for the wiring at the end of the grip. The orange /gold one you have to be more careful cutting off the old grip so you don't damage the underlying wire.
    Good luck.. post up your results
    http://www.i-bmw.com/showthread.php?...light=pos+grip
    NCS
    03 K 1200RS (Black is Best)
    03 Honda RC51
    74 Honda CB750 K4
    Registered User arthurdent's Avatar
    Central Nebraska
    Have you considered BeemerBuddies to go over the handgrip? Yeah, I realize the old joke (cheapest thing on the Beemer is the operator) but it worked well for me in a similar situation, and I got a larger grip out of it.
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Ufda happens..........
    Just north of Seattle, WA
    Quote Originally Posted by arthurdent View Post
    I 2nd this motion.
    The left grip on my 2002 RT-P started to come apart on the underside of the grip. I had just purchased a new GSA, and in the process of asking what "must-have" after-market equipment I'd want on my GSA, I learned about BeemerBuddies. I ordered a set for both bikes, and they completely eliminated the "grip coming apart" problem on the RT-P. I've put about 5K miles since, and they don't show any wear whatsoever. It does not degrade the output of the heated grips at all. FWIW, I ride 200 miles a week, year-round in Seattle. I know a thing or two about riding in the cold, wet and dark
    Seattle, WA
    2012 R1200GSA
    2002 R1150RT-P
    1992 K75S sold
