Results 1 to 9 of 9
Thread: /5 headlight
    Apr 2011
    /5 headlight
    Attached a pic of my /5 headlight reflector and bulb holder. (Original type) Trying to figure out what is missing. In other words, what holds the bulb, bulb holder, and spring onto the reflector? Could have sworn I saw a pic on the web somewhere of what its supposed to look like, but can't find it now.
    Thanks in advance!
    From RealOEM:
    http://www.realoem.com/bmw/showparts...39&hg=63&fg=05
    Looks like you have Items 1 and 2...not sure how it's supposed to attach to your reflector. Let's hope you have the right reflector.
    Pismo Beach, CA
    From MAXBMW's microfiche.
    The bulb support [underside]. It engages tabs on the reflector and is held in place by the tension of the spring against the reflector (the bulb is "trapped" between this part and the reflector). A fractional turn of the support "locks" in place. This one is apparently a later replacement part (spring connector vs. spade connectors). The OEM reflector is NA.
    Did this reflector come out of your bike? It doesn't look like an OEM part; the tab on the outside diameter (at 3:00) shouldn't be there.
    Another shot showing the tabs.
    Lew Morris
    1973 R75/5 - original owner
    Apr 2011
    The reflector is made in Germany with a 1 305 313 902 stamped on it. The lens is a Bosch, so I am assuming it is original. It has no tabs for the the bulb holder to lock on to, nor do they look like they've been broken off. There are two small holes that I thought may be for a wire bail, even though I didn't really see how that would work, either. I seem to remember a wire bail involved in a BMW headlight somewhere....
    This is from a 72 R60 junker I bought just for the headlight bucket and speedo. It was just hanging by the wires when I got it.
    The number is not a part number...no headlight part for a /5 or even a /2 has that kind of number associated with it. No telling what the reflector really goes to.
    Registered User ebeeby's Avatar
    Your tabs are broken off. That reflector looks correct - I just compared it to one I have the garage. It has this number on it
    0303550000?2 (not sure about last 0)
    If you need a reflector assembly I have one.
    Pismo Beach, CA
    Just backing up EBEEBY's observation; the tabs are broken off. I converted to H4 and had my old OEM at the shop. The tab at the bottom IS there (memory is fading) and covered by the rubber gasket (that holds the lens onto the reflector.
    Lew Morris
    Apr 2011
    What are you asking for it?
    / mod hat on /
    Please, keep any buying/selling/trading off the tech forums. Either use PMs or go to the Flea Market.
    Thanks...
    / mod hat off /
