Results 1 to 4 of 4
Thread: Waterless coolant
    On the Road
    Aug 2012
    Northern California
    Waterless coolant
    Hi Guys
    I saw a show (Wheeler Dealers) the other day that showed them installing a waterless coolant in a car. I had never heard of it before. They said a lot of good things about it. I went to a website for Evans waterless coolant to check it out. The reviews were very good, with one person with a BMW LT that really liked it too. I'm thinking about getting some.
    Any thoughts or experiences with it? Anybody know off hand how much the coolant capacity is for my K1200GT? It's like $35 per gallon. If I change I'll report back in with the results.
    John
    EVRNEWBIE
    K1200GT cooling system capacity.
    From the trusty-rusty DVD... 3.5 Liters. "Nitrite-free" and "with corrosion-inhibitors" are the only specified qualities, which isn't really helpful on-line researching.
    I saw this stuff on Amazon and eBay, and I smell snake-oil, though that's hardly scientific or even rational. This seemed like an internally- and externally-consistent source of information: http://www.machinerylubrication.com/...t-fundamentals
    Given that others here have reported finding Prestone or other commonplace brands that work AND cost 1/3rd of BMW's re-branded Pentosin (which isn't much cheaper), may I suggest caution here? I'd love to know if this stuff works, but I'd rather hear a chemist explain it than have you run the risk of a wrecked motor. Note that even if your engine ISN'T wrecked prematurely, we still won't have usable proof that this stuff is safe/effective.
    My 2 cents, and not worth even half that.
    Ben
    On the Road
    Aug 2012
    Northern California
    waterless coolant
    Thanks Ben
    What I have found out so far is that the enemy to the engine from water type coolants (including antifreeze mixes) is electrolysis that causes the metals in the water passages to degrade. It is apparently caused by the pH of the water.
    The waterless coolant contains no acids so that is why it is advantages. I'm still researching.
    Thanks for your input.
    John
    Albuquerque, NM
    Don't just do something ... sit there.
    This should be the response to "liquid solutions."
    Kent Christensen
    21482
