Results 1 to 3 of 3
Thread: ESA Issue 2007 R1200RT
    The ESA on my 2007 RT has just started to exhibit a problem. When scrolling through the various settings, it will not go from two to one rider position. Seems to change all other settings. Is this the beginning of full failure, or just a glitch? Can this be repaired or manually changed? Any ideas?
    Last edited by deilenberger; 01-16-2013 at 06:08 AM. Reason: added year/model to title
    Sheboygan, WI
    Thumbs up
    Quote Originally Posted by 1998gsrt View Post
    While the sensors that manage the ESA can fail (one did on my RT), a more likely path for you to pursue would be to have the dealer do a computer 'flash' and re-boot next time you're in for service.
    This fixed an identical problem I had early on with my '05 R1200RT. Perhaps this will clear up your anomoly.
    Dear 1998gsrt (real name? We're friendly around here..)
    Please read: http://forums.bmwmoa.org/showthread.php?46055 - Since ESA has had several generations since intro having this info in your thread title would be useful in perhaps attracting someone who experienced the same problem open the thread. Generally - the more descriptive your thread title is, the better the answers you'll receive. Plus it helps others searching for the same issue later on to spot the thread.
    I'm editing your thread title to add that info.
    Welcome to the forum! One thing you might do is fill out your user Profile, and add your name, and bikes you own to your "sig" - then it will be added to every post you make on the forum. Having some idea where you're located may also help local people who may be helpful to know they're local to you and get in touch.
    Best,
