Results 1 to 4 of 4
Thread: Replacing rotor - have question about adding diode as backup to exciter circuit
Hybrid View
    Registered User ohiorider's Avatar
    Apr 2005
    Hudson, Ohio
    I ran the first two tests Rick (Motorrad Elektrik) provided me a few years ago, and it is obvious the rotor on my R100GS is shot, so it'll be replaced. I always first suspect the 'gen' lamp, since if it is blown, the alternator doesn't receive the exciter current necessary for it to operate. However, the lamp tested 'ok', (came on when I grounded the DF terminal against the engine block with ignition on.)
    Question - I cannot find info on exactly how to wire a diode into the exciter current circuit, so that if the 'gen' bulb fails, the alternator will still receive exciter current. I recall reading about this fix several years ago.
    (a) can someone point me to a link to that fix?
    (b) is it necessary to install the fix in the dashboard housing (undesirable), or can it be installed elsewhere on the bike that is more accessible?
    (c) does the fix work in conjunction with the 'gen' bulb, or must the bulb be removed for the diode to work?
    It's not a diode but a resistor. Snowbum discusses it here:
    http://bmwmotorcycletech.info/genlampresistor.htm
    The resistor works in conjunction with the bulb...there's no need to remove the bulb.
    Jul 2010
    Tularosa, NM
    Rick Jones
    Rick makes/sells these for just a few bucks. EZ.
    Walking Eagle
    Apr 2005
    Hudson, Ohio
    Thanks for the info.
    Bob
