Results 1 to 5 of 5
Thread: '04 R1150R Headlight Relay
    Astatula, FL
    I want to add a relay kit from Eastern Beaver. I see on the website that in addition to the standard kit that mounts the relays in the headlight shell, Jim offers a waterproof kit for GS models and bikes with a small headlight shell.
    The R shell looks small, is there room inside it for the relays?
    Bob Weis
    '04 K12RS - Hannigan Hack
    www.earplugco.com
    #13338 PGlaves's Avatar
    Quote Originally Posted by Bobmws View Post
    I don't think so. I'd go with the relay external to the shell.
    Registered User tourer1150's Avatar
    Feb 2011
    no relays, no fuses
    Hallo Bob,
    my guess is you're looking at the non-H4 headlight kits. If you can do cable connections yourself I would recommend a look at the PDM60. Yes it is $149, but no fuses and no relays to control a total of 60Amp over 6 outputs. Meaning you are covered for your next projects.
    Here is a nice video about it
    http://www.youtube.com/watch?v=c83l-41RbjI
    The product page itself here
    http://www.rowe-electronics.com/modules
    I haven't ordered it myself yet, because I'm still checking how to configure it completly. But I'm planing to hook up the low beam, PIAA1100X, heated gear, GPS and Photon Blaster. I started looking because I'm fighting the RT headlight ground problem (burnt) right now. While I'm messing with ground, I'm planing to connect the low beam directly to a 12V PDM60 output. Some say a direct 12V connection gives you more juice at the bulb instead going thru the 'old' BMW switches and connectors. The 7 second PDM60 delay will also allow me to start a very cold engine without the headlight turned on.
    Have a look.
    Joe
    Astatula, FL
    Thanks Paul.
    Tourer, Single H4 bulb on the R model.
    Bob Weis
    www.earplugco.com
    HOTTECH
    May 2008
    Concord,N.C.
    Headlight Relay
    I have the Eastern Beaver headlight relay installed in my 2004 R1150R and it all fit in very snugly but does fit.
