Results 16 to 17 of 17
Thread: Swapping out lamps for LED's in guage cluster ?
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Quote Originally Posted by snookers View Post
    Thanks to all for the replies.........I love it when I can learn from asking questions. What I intend to do is to swap out the incandescent bulbs in the speedo and tach with LED's.......I am also swapping out the turn signal lamps with LED's.....green ones...now if they are too bright, this for me at least, will be a good thing as perhaps I won't be inclined to leave my signals on after making a turn. The other warning lamps will remain as they are since they will most likely never burn out as they aren't illuminated for very long anyways. The 3 watt battery/alternator lamp will also remain, and I will definitly aquire a spare.
    Please post back regarding the green LEDs I am most curious if they will be brighter.
    They will get your attention better as they are instant on and off.
    Ufda happens..........
    DBLUPPR snookers's Avatar
    Jul 2010
    Southwest of Beamsville
    Well the deed is done...........................
    I swapped out the incandescent bulbs in the Speedo and Tach with red led's, and I must say that the change is quite significant. Easy on the eyes as well. The incandescent bulbs in the turn signal indicators were also swapped out with green LED's.......they are really bright.....like shimmering emeralds. A seperate red LED was installed over the three switch's on the dash panel .....so no more fumbling at night as to what is what. The light streaming towards the left side of the speedo is from that LED. A small cover to direct the light to the switch's only will be installed soon.
    This was a good mod.
    The LED's were a tad pricey, but with that said, I got what I wanted and am pleased with the results.
    http://autolumination.com/74.htm
    The bulb/Led's used are the #24 "Superstar" High-Flux low profile Leds With Lens Covers located about a third way down their web page
    2000 R1100RT
    Niagara BMW Riders #298
    BMWMCO #45
