Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: 2003 R1150RT To lube the spline or not to lube the spline
    On the Road
    Jul 2011
    Hi all,
    I purchased a 2003 R1150RT with 27K on it last year. I have been very happy with it and want it to last. That being said I'm tipping in at about 300 LBS and ride reasonably aggressively. Of course the best thing to do would be to lose weight but seeing as I, in essence, ride 2 up all the time I am wondering about if and when I should have the spines lubed. I have a great mechanic who I trust to do the job but I question if and when I need to do it. The bike has 38K on it now and at first I was thinking I would have it done at 40K. I am experiencing no unusual symptoms and have no concerns about the bike. My only real concern is about what I have read regarding spline failure and possible prevention. Any opinions?
    Jon
    every 40-50K is a good idea in general (so asserts PG). Your extra weight probably does not impact spline lube wear. Once your bike starts experiencing symptoms (difficulty downshifting, usually 3 to 2 or 4 to 3), you have only a few thousand miles before full failure happens. And Murphy's Law tells us that will NOT happen anywhere convenient. I'd do it this winter if it was my bike.
    Apr 2005
    You can also check the condition of the splines by pulling the starter off and looking into the slot. Tie off the clutch lever, then rotate the clutch disk back and forth with a small tool. The disk and the splines should turn in unison. If not, you have problems.
    Here's a youtube video that will give you the idea. He has a small amout of movement.
    http://www.youtube.com/watch?v=UGg9H...ature=youtu.be
    On the Road
    Jul 2011
    Thanks guys, I am now planning on having it lubed before 40K
    May 2008
    Adirondaks and LI,NY
    There are a few good threads started offering pictorials of the service, take advantage of them here in this forum.
    Jun 2012
    Worth watching, no affiliation and haven't tried myself yet. Sounds like the m/c was one with the worst factory defect of mis-aligned engine - transmission to fail drastically and quickly and repeat.
    May 2008
    Last year I created a pictorial of the entire process of disassembly of the 1150RT. Also included were the locations of all threads I found concerning the same on BMWMOA. I did a search and can not find this thread. Could the moderators assist with this? Search for "A pictorial Spline Lube"
    Jammess jammess's Avatar
    Aug 2005
    Florence, OR.
    Ok, I wonder how hard it would be to replace the hydraulic clutch assembly with a mechanical cable operated system like the 1100's used? I see no advantage to the hydraulic system, NONE!
    Jammess
    Jun 2012
    Quote Originally Posted by OLSENSAN View Post
    This:
    http://forums.bmwmoa.org/showthread....RT-Spline-lube
    Thanks much for putting together.
    Search hint. Use Google "Pictorial-2002-etc site:http://forums.bmwmoa.org"
    Quote Originally Posted by Red100RT View Post
    it would be hard. very hard. next door to impossible kind of hard.
    Take a look at the clutch cable assembly and associated parts in a R1100 parts fiche, and then compare that to the 1150's or 1100S's hydraulic system.
    May 2008
    Thanks GKman!
    On the Road
    Jul 2011
    Quote Originally Posted by GKman View Post
    This:
    Awesome, Thanks!
    Massachusetts
    A couple days ago when I was working on the starter I had a look at the splines. After tie-wrapping the clutch handle to pulled in, I looked for movement between the hub and aplines. At the clutch plate outer edge I had about 1/16 of an inch of free movement before the splines also moved. This calculates to about 1 degree. I'm assuming this is fine.
    Can I ride with piece of mind that all is well?
    Loading the Bike
    Nov 2012
    Chris Harris, who prepared the above 5 minute video in his Manchester, NH shop, believes many of the 1100 and 1150 machines have a design defect in the interface between transmission shaft and clutch assembly (3 mm gap), such that the transmission splines do not fully engage. He uses a redesigned clutch plate manufactured by Bruno Sax (http://www.brunos.us) in Canada, which closes that 3 mm distance to achieve full transmission/clutch engagement. Interestingly, he believes those riders like me - who tend not to wind the rpms out in each gear - are more likely to have the spline problem with their bikes than riders who push their machines harder. He says riders who have installed the redesigned non-OEM clutch plate do not have this issue, which is not a function of lubrication, he maintains. Interesting ...
    Quote Originally Posted by Muchogum View Post
    about 6 or 7 yrs ago there was a guy in Canada (pretty sure it was not Bruno) that did basically the same thing. he had made up some prototypes, and was offering kits for sale for about $1G. never sold well- as stock parts were less than 1/3 of that, and most prospective buyers (he had posted on Pelicanparts.com's ) didn't see themselves replacing the clutch pack 3+ times.
    do you know what Bruno's charging?.. i did not see the items on his website.
