Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 31 to 45 of 136
Thread: 1973 R75/5 Rebuild Project Journal
  1. #31
    B Reams brook.reams's Avatar
    Arvada, Colorado
    1973 BMW R75/5: Progress Report
    At this stage in the project, the bike is apart. Last week, I took the frame, sub-frame, center stand, battery box halves, headlight ears, license plate bracket and the handlebar controls to Brad at BFN Industries, a local company near me in Arvada, CO.
    Parts for Powder Coating
    Zip Ties Marking Threaded Holes
    You can see more on my progress including the work plan at my web site, 1973 BMW R75/5: Progress Report
    Brook Reams - Arvada, CO
    Meliora cogito.
    Various Two-wheeled Vices, All BMW
    2004 R1150-RS||2002 F650-GS||1983 R100RS||1975 R75/6||1973 R75/5
  2. #32
    Arvada, Colorado
    1973 R75/5 Parts Back From Powder Coating
    My parts are back from powder coating by Brad at BFN Industries. I wrote a check for $190 and change. I think this was a good price.
    I posted a number of pictures here, 1973 BMW R75/5: Powder Coating Done in my latest blog post.
    Also, I'm posting all the pictures I take here on Flickr --> 1973 BMW R75/5 Rebuild
    Here are some from the blog.
    Faring bracket rust
    Frame Corrosion
    Paint and rust
    Frame Corrosion
    Battery Box Rust
    Battery Box Corrosion
    Left Control Disassembled
    Left Handlebar Perch
    Powder Coat Presents
    Presents from the Powder Coater
    Powder Coat - Controls
    Handlebar Control Perches
    Powder Coat - Frame, Sub-frame
    Frame and Sub-frame
    Meliora cogito.
  3. #33
    Arvada, Colorado
    1973 R75/5 Clutch Throw-out Rod Wear
    Here's a link to picture of the throw out rod. I've not seen a new one, so I don't know if the ends look OK or show abnormal wear.
    What's the opinion of the knowledgeable?
    Clutch throw-out rod
    .Clutch throw-our rod
    Meliora cogito.
  4. #34
    Mar 2012
    Lexington, IL
    I'd say you did good price wise on the powder coating. I got the "family" discount last fall and paid $150 just for frame and subframe. I'm guessing I'd have been over $200 for what you did
  5. #35
    Pushrod
    Brook -
    I'd say the pushrod tip looks fine. The aft end, though seems unusual with the wear right next to the step. Not sure why it would do that. If that allowed any sideways movement of the race and/or bearings, it might be worth a replacement.
  6. #36
    Pismo Beach, CA
    Hey Brook. I see lots of parts but I don't see control perch wedges; referred to in an old thread on this site as the Triangular Thingy Doofer (TTD).
    They get lost early on in the life of most old airheads. Sometimes the perch will grip the handlebars sufficiently not to rotate without them, but sometimes not.
    If you look "inside" the perch you will see a "V" shaped groove molded into the perch at the split line; the wedge slips into this "V" when it is placed on the handlebar. It's a tight fit.
    When I had my perches powder coated the over-spray filled in the grooves just enough that I could not get the wedges back in; I removed the paint to get back down to bare metal.
    The wedge is item #13 on the drawing. P/N: 32 72 2 072 223 - they are listed on many BMW sites as NA (not available), but they are... Hucky has them. They do come dearly.
    The "divot" on the backside allows the pinch-bolt to pass over the wedge.
    The "internal" side is serrated longitudinally (you can see it in the bottom pic) to better grip the handlebar tube.
    Lew Morris
    1973 R75/5 - original owner
  7. #37
    Monza Blue 1974 R90/6
    Delaware
    I agree with eagle eye Lew. If you don't have the triangles, get them and put them in. Otherwise, the clamps won't be tight enough, the controls will move, you will find yourself "snugging" them up, and then they will strip.
    One other thing, I'm pretty sure your levers have a nylon bushing where the pivot pin goes through. You can replace the bushings for a dollar or so to tighten up the levers.
    Barron
  8. #38
    Arvada, Colorado
    Quote Originally Posted by Barron_Williams View Post
    Barron
    Lew and Barron,
    Indeed, I hadn't removed the "perch" wedge from the control barrels when I took that picture. But, they are safely squirreled away in the zip-lock bag for each control. Thanks for calling out how critical they are.
    Thanks for the tip about the nylon bushing. I'll look into that.
    Best.
    Brook.
    Meliora cogito.
  9. #39
    Arvada, Colorado
    Brook -
    Hi Kurt,
    I'll look at the aft end more closely. Perhaps a new throw-out rod makes sense. Checking Hucky's site:
    23 21 1 230 106 clutch thrust rod / 5 4 speed $ 22.40
    This isn't priced like Germanic Unobtanium :-)
    Best
    Brook
    Meliora cogito.
  10. #40
    Arvada, Colorado
    1973 R75/5 Powder Coating Update
    I posted an update about cleaning up any over spray of powder coating. Permatex Gasket Remover works very well.
    http://brook.reams.me/2013/03/07/197...-coating-done/
    Put Permatex on Threads of Swing Arm Pivot
    Put Some on the Bolt to Soften Any in the Threads
    Meliora cogito.
  11. #41
    Arvada, Colorado
    1973 BMW R75/5 Rebuild: Refinishing Headers, Headlight and Steering Damper
    Over the weekend, I dove into refinishing some of the high profile parts. I documented what I did in separate web pages under the "51" category for "Vehicle Trim". There are lots of pictures showing before and after: here are the links.
    51 BMW R75/5 Headlight Shell and Switch Housing Paint Repair
    51 BMW R75/5 Restoring Header Pipes
    51 BMW R75/5 Refinishing Steering Damper Knob
    Headlight Shell Restoration
    97,553 miles, 2 owners
    Headlight Shell After 40 Years, 97,553 miles
    Headlight Shell Underside Detail
    Headlight Shell Underside Grunge
    Headlight Paint - Like New
    Headlight Paint Repair - Like New Again
    Refinished Switches
    Restored Switch Assemblies
    Header Restoration
    Header with 40 Years of Bluing
    Header Cleaned & Polished
    Restored Header Clean & Polished
    Steering Damper Restoration
    Steering Head Grunge & Damper
    Steering Damper Dings and Steering Head Grunge
    Steering Head Polish $4
    Steering Head After Polish #4
    Meliora cogito.
  12. #42
    Eastern KY
    Brook, I haven't heard back from the guy in Lou,KY that had his bike striped but I'm going to the same guy after I paint my fenders-tank stripes I'm still deciding as I change my mind back/forth on those. The blinker switches-did you spray clear on the levers?
  13. #43
    Arvada, Colorado
    Hi Kentuckid,
    The clutch and brake levers are just polished, no clear coat. I hadn't thought about putting clear coat on them. The switch housings also have no clear coat. That's the level of gloss in the Dupli-color Universal Black touch up paint.
    Keep me posted on the stripes.
    PS: What did you teach when you taught?
    Best.
    Brook.
    Meliora cogito.
  14. #44
    Arvada, Colorado
    1973 R75/5 Renewing Cylinders, Valve Covers & Heads
    I wrote up a web page on this and here is the link.
    I sent the cylinders, valve covers and exhaust nuts for bead blasting to a local shop in Arvada, CO, Roadies Performance, that does bead blasting for me, and send the heads for a complete rebuild to Randy Long.
    Here is a sample of the pictures I took and there are more in the web page.
    Bead Blasted Cylinders, Valve Covers and Exahaust Nuts
    Bead Blasted Cylinders, Valve Covers and Exhaust Nuts
    Rebuilt Heads
    Rebuilt Heads by Randy Long
    Airbox Covers, Before Polish & After
    Air Box Covers, Before & After Clean Up
    Meliora cogito.
  15. #45
    Feb 2009
    Chicago, IL
    Nice work!
    What did you use on the headers?
