Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
Thread: Mixing Oils
    Geek jlevee's Avatar
    Feb 2006
    Phoenix, AZ
    Mixing Oils
    I am sure this question has been asked & answered many times over, but I did not see it in a search.
    Over the years & oil changes i have wound up with all sorts of miscellaneous partial quarters of oils sitting around in my garage. 15w50, 20w50, synthetic, dino, etc. All of this has me wondering... is it safe to use different oils to top off so i can get rid of these? Like say is 15w50 safe to add to what is essentially a 10w40 oil change? what about adding a dino to a synthetic?
    SW Ohio
    Don't think there is any harm mixing dino and synthetic. I mixed 50-50 10-30 Mobil 1 and Castrol 20-50 to make a 15-40 winter blend for my Ural. I just try not to stray too far from the recommended weights for the vehicle. But I always manage to use up leftovers by topping off the van or VW with whatever.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Oil is cheap...relatively speaking. And old oil sitting around can absorb contaminants that you might not want to put into an engine. On top of that, blending oil is done by engineers to achieve a specific additive package. There is little guarantee that such garage-blending will do any good...likely it could do harm. If you were needing some oil to get you another few miles down the road to a service station or an oil change or something, that might be OK. IMO, it's not good practice to use the oil up in this way in your bike. I wouldn't.
    Diamondhead, MS
    Just take it to any parts house, oil change facility, etc and they will recycle it.
    mattituck new york
    when you order bmw oil in the u.s. it comes in quarts
    the bmw manual says to put in liters which have 6% more oil in them than quarts. if you want to make up the difference with what you got layin' around. i'd do it, which i already do (if i bother to do it at all).
    i change the oil in the fall and halfway through the summer pretty much regardless of mileage. the filter only gets changed in the fall.
    maybe if you use oil from fake dinosaurs, you might not wanna mix it with oil from real ones, although i doubt the effect on the engine could be quantified by a scientific scientist.
    oh yeah, i got my first bmw in 1964. (i'm a lot younger than i look).
    Quote Originally Posted by jlevee View Post
    ............. Is it safe to use different oils to top off so i can get rid of these? ............
    yes!!!
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Nickname: Droid
    Jun 2005
    Green Bay, WI
    Not sure about this comment, I quote; "old oil sitting around can absorb contaminants that you might not want to put into an engine." Where would these "contaminants" be absorbed from? Sure, an open container will collect debris and dirt, but not a sealed container.
    If the oil is in the original container and capped, nothing can contaminate it. There is no problem in using oil "remnants" and the affects of blending minimal amounts of additives likely has little detriment to the used oil in the engine.
    I don't consider these "sealed" containers all that very well sealed. The oil is going to absorb moisture (my opinion) and why would you put oil that already has moisture in it in an engine? There will be enough chance for the egine to do that all by itself...I see no reason for helping it along.
    Dirty oil is better than no oil; clean oil is better than dirty oil. Just do what works for you. Me, I'll use the best clean oil I can find from a fresh container and recycle the rest.
    atlanta
    Thanks for a correct answer.
    Marty Hill
    12 GS black/Boxer Cup Replika
    ride till you can't
    Feb 2006
    I think you got it exactly right.
    Dale Rudolph
    May 2009
    Medford, Oregon
    One way I get rid of a little oil left in the bottle is to put it into one of my "Squirt" type oil cans. It doesn't matter what weight it is or whether it is dino oil or synthetic, when you want to squirt some oil onto
    something, it works.
    The oil is going to absorb moisture (my opinion) and why would you put oil that already has moisture in it in an engine? ...............
    Glad you qualified that statement as opinion, because it has NO basis on fact. Oil is hydroPHOBIC, not hygroSCOPIC. Oil, diesel, gasoline and most if not all petroleum products can be left in an open container and no water will be absorbed.
    Glycols, and Alcohols on the other hand will absorb H2O
    http://www.bio.brandeis.edu/classes/...bic_effect.pdf
    One Man Wolfpack Kent Niederhofer's Avatar
    Jul 2010
    West Bloomfield, MI
    Mixing Oils
    I generally value the insights gained from this website based on the experiences of others but I really have a hard time when people voice their "opinion" but don't actually know what it is they're talking about as it creates confusion and substantially devalues the forum. So regarding the questions asked by the OP, let me make clear that in general oils are hygroscopic, that is they tend to absorb water moisture and so with time they will deteriorate. Also, with respect to the mixing of oils of different viscosities, I did find this on the Exxon-Mobil website, which is a source I'm more likely to trust than most people who have "opinions" which is just about everybody (URL: http://www.mobiloil.com/USA-English/...scosities.aspx).
    Glad I could help!
    Kent
    Quote Originally Posted by pffog View Post
    Quote Originally Posted by der kaiser
    Hmmm... Now I'm really confused!!
    In the end, everyone can do what they want. I think it shortsighted to just combine oils for the sake of saving a few pennies or "finding some place to put the oil". Oil can easily be recycled. It's a critical element to an engine's health. If there is any doubt at all, I wouldn't do it. That just me...
    Quote Originally Posted by Der Kaiser View Post
    Kent -
    That website specifically states Mobil 1 viscosities. I wouldn't have any issue with using oils from the same manufacturer. But is it a universal truth that any oil, any viscosity, dino/synth can be mixed? I would doubt it.
