Results 1 to 15 of 15
Thread: 1987 BMW K100RS Throttle Tension/Throttle Lock/Cruise Control Suggestions
    On the Road
    Dec 2012
    Akron, OH
    I just got my first bike- 1987 K100RS. In riding a little over a hundred miles, I've come to realize that I don't like how much spring tension I have to overcome to turn the throttle. It's completely stock at this point, but I'd like to do something to lessen the tension.
    From what I've read, it seems like the consensus is to add something like Throttlemeister bar ends in order to lock the throttle open. My first question to those of you have used these is: how have they worked for you? Are these only ideal for situations when you are on the highway at cruising speed?
    My second question would be: is there another solution that is better than the Throttlemeister bar ends? Another product that is superior? If the Throttlemeister is only usable at highway speeds, is there another product that works at more than just highway speeds?
    Thirdly: is there an adjustment to be made on the bike that will lessen the spring tension of the throttle? I've read the Clymer's manual on the throttle, and I find no mention of spring tension anywhere.
    As you can tell, I have absolutely no knowledge on the subject and am looking for suggestions and guidance on the matter. Anything would help! Thanks!
    Belton Tx
    BMW sells a throttle friction screw that mounts to the bottom of the throttle housing. Part # 32721454414. I have one on my 91 75RT and it works well.
    Ron
    91 K75RT ABS
    Registered User heejrbmw's Avatar
    Aug 2009
    Boone, NC (Mountains of Western North Carolina)
    Friction Screw
    Quote Originally Posted by tmwkicker View Post
    You can use a friction screw to aid in your desire. I looked at four OEM Parts dealers. Max BMW is the only of the four that has the friction screw listed. It is listed for $9.65. I use one on my K75 and find it helpful.
    It goes in the housing on the right side of the handlebar.
    Ed Evans - - Semper Fi
    '94 K75 '92 K75S
    "Always do more than expected." Coach Jerry Moore, ASU
    Aug 2009
    Friction Screw / Housing diagram
    See diagram. Item number 26. Part number 32 72 1 454 414. $9.65.
    '94 K75 '92 K75S
    Aug 2009
    Sorry Ron. I see I duplicated your effort.
    Quote Originally Posted by roncooper View Post
    As Ron said.
    '94 K75 '92 K75S
    Mar 2007
    Chicago, Ill
    Be aware
    Not every handlebar assembly came drilled and tapped to accept this screw.
    Quote Originally Posted by Beemer01 View Post
    Easy to check before ordering. The holes were sealed at the factory with a small plastic plug that pulls out quite easily.. It's sort of half-under the throttle assembly, from memory - just below the pivot mounting for the brake lever and a bit inboard. Perhaps someone can post a photo of one installed.
    Out There Somewhere ricochetrider's Avatar
    Harrisburg, PA
    +1: RE: Friction Screw
    I have a friction screw in both my 88 K100RS and my 93 R100RS. I like it because it does allow me to relax a bit. This is especially helpful on longer rides or journeys. It was a bit of a paradigm shift for me tho- one thing you HAVE to remember is that you HAVE to "unwind" the throttle manually, to shift, or slow down. If this is your first motorcycle, then maybe you don't have a bunch of habits developed... yet. For me, having the throttle more or less locked all the time, I had to learn to move it to whatever position I wanted it in at the appropriate time, IE; shifting, slowing, stopping, etc.
    Of course it didn't take long, but I had at least one "surprise" moment.
    One nice thing about the screw is that it's easily adjustable- simply reach down and tighten or loosen it to your liking/needs.
    Just my two cents worth.
    BTW, best of luck with the new ride!
    Be The Change You Want To See In The World
    Quote Originally Posted by bmwrider88 View Post
    given that vast majority of time you are NOT in "cruise at steady speed mode" (hopefully!), best solution is to just set the screw for a bit of drag to slow the return, but not get in the way of controls manipulation.
    To the OP- The early K100s should all have the tapped opening for installation; this is by far your best and most cost-effective solution. Throttlemeister should really only be considered if this screw is not a ready option (like on my previos '94 K11RS, or my current '01 R11S).
    On the Road
    Dec 2012
    Akron, OH
    Thanks everyone for your input.
    I went and checked, and my 1987 K100 is one that is already tapped for the tension bolt. I will go ahead and purchase the bolt from Max
    BMW.
    Ash Grove, MO
    ...for a cheap alternative
    Here is my copy of what some companies are selling for 20 bucks. It is a piece of 12ga solid core house wire, twisted around my throttle grip. I just roll on the throttle, use my index finger to push the twisted wire down until it touches the brake lever, and 'walla', my throttle stays set. It will hold steady speed for about a minute, then vibrations start to let it creep back down. If I close the throttle manually, it just rotates on the grip.
    Total cost, 99cents for the little plastic vacuum cap on the end.
    Mike Davis
    1985 K100RT
    1998 R1100RT
    May 2004
    boise, idaho
    Of course there are other options. Why not consider a Wrist Rest or some other gizmo of essentially the same design? They are widely available, can be easily removed and used on any motorcycle, and cost very, very little.
    K75RT Keith
    Apr 2011
    Rocky River Ohio
    I have an extra throttle screw. If you are interested, em me
    On the Road
    Dec 2012
    Akron, OH
    Quote Originally Posted by KKELLER149854 View Post
    Thanks KKELLER149854. I ended up purchasing the BMW throttle screw and have been able to try it out a few times. It is exactly what I needed!
