Results 1 to 11 of 11
Thread: 2011 R1200 gs known issues
    Ok
    I am looking at purchasing a new to me used 2011 1200 GS.
    I know they have the new float system and not the wonderful strip,what I do not know are the issues that have cropped up with this new cam head engine.
    If you could comment on this I would appreciate that.
    Please do not limit your comments on the engine only
    Are the final drives the same as the 2008?
    Dave
    I have a 2011 R1200GS that I bought new. It now has 47,000 km on it and I have had no issues of any kind. Just routine maintenance.
    I was anal during the break-in period to strictly comply with BMW's instructions regarding maximum RPM. Up until about 30,000 km, it was using some oil. Now that it is broken in, it is not using any oil to speak of; I don't have to add any oil between oil changes, which I do every 10,000 km. I switched over to semi-synthetic at approx. 30,000km and to full synthetic at approx. 40,000km. I am using 10W40.
    Mine has ESA\ABS\ASC.
    There is at least one design change from the rear drive on the 2008 (I had an identical 2008 which I also bought new,and which I was also anal about during break-in, and which also did not use any oil to speak of after break-in, and which was totalled when I was rear ended at 85,000km). The rear drive on the 2011 has a rubber-covered vent\breather on the top that was not on the 2008. I believe this same model of breather is also on the top of the transmission gear box at the engine. So far, I have never had any problems with either rear drive. I change the rear drive oil every 10,000km rather than every 20,000km, just as a precaution. I use Castrol SAF-XO in the rear drive.
    So far, I really like mine.
    Dave McDougall
    2011 R1200GS
    Registered User Tewster2's Avatar
    Fines Creek NC
    I am also interested in issues. 27,000 miles on my 2011 so far. I do blow out a headlight bulb every 12,000 miles but that is normal as far as i can tell ($8 from auto zone). I'm ocd with servicing and final drive lube change every oil change.
    Registered User BlackdogGS's Avatar
    Sep 2010
    Zillah WA
    I have a 2010. No issues at all other than an occasional headlight bulb. I use no oil between changes.
    Nov 2005
    El Dorado Hills, CA
    I have a 2011 R1200GS with 30,000 miles and no problems other than a new headlight bulb every 8,000-10,000 miles.
    Doug Printz
    El Dorado Hills, California
    - 2011 BMW R1200GS
    - 2005 Honda ST1300
    Thanks for the response
    I purchased a 2012 1200 gs Rally edition.
    now I need all the kit.
    anyone have a nice used set of adventure cases for sale?
    Dave
    Apr 2007
    Tampa, FL
    DSC02974.jpg When you get finished, it may look something like this...
    DeLand Florida
    Quote Originally Posted by dwestly View Post
    Beautiful.
    Apr 2007
    Tampa, FL
    Yeh, I ride it as more of a sport tourer than an off-road beast. My 4th GS, with lots of bikes in-between, but I always come back to the GS. Just fits me and my riding style...I think I'll wait a year or two on the new wasser-boxer though, just to make sure they've got it ironed out LOL.
    Nice looking bike.
    I see you have the touratech light gaurd with the removable lense, does this vibrate or shake while riding at night?
    Might need one of those.
    I like the way it looks with the adventure luggage set up
    Dave
    PS
    I was in Tampa last Febuary and picked up a Moto Guzzi Norge and rode back to Colorado. Very nice down there in the winter.
    Apr 2007
    Tampa, FL
    Light guard is very secure. I'm sure a lot of that has to do with the wind pressure against the front of the guard, keeping it securely in the mounts. You do get the high beam reflection in the bottom of the windscreen, just like with others. I don't find it that distracting, so haven't applied the light block sticker they supply with the guard. The guard is easy to install, and the easy removal makes it much easier to clean both it and the headlights.
    I'm a huge fan of the BMW cases. Yeh, I know they're expensive, but far superior to the standard GS cases, hold more and look good on the Rallye, too. I usually ride locally without the topcase and save it for long trip packing. The sidebags hold more than enough, including all tools, tire repair kit, first aid kit, air compressor, rain gear, clear faceshield for nights, etc and room for more. I hate clamshell-opening side bags...
    Winter...what's winter? 80 here today. My wife and I are teaching a sportbike class tomorrow and it will be 82 degrees. On the other hand, you should be here in August, when its 100 degrees and 95% humidity. This is the best riding weather of the year right now for us. We can actually wear leathers, instead of the usual armored mesh gear.
