Results 1 to 15 of 18
Thread: Very reluctant starting of RT
Hybrid View
    May 2010
    I have put away my R1200 RT (2012) for the winter just three weeks ago. I have filled her up, added fuel stabiliser, and put her on the battery charger. Yesterday, I wanted to check some connections for my heating jacket, so I started the bike. Rather, I tried to start it. It wouldn't. The battery was absolutey topped, and it cranked all righ, but it took me about 10-15 minutes of cranking, shutting down, waiting, cranking again before the bike finally started to cough and spit and start wheezing and shaking away, with an awful sound. And I really had to hold the starter running a long time, otherwise the engine would choke and die. Then I had to wait a good 5 minutes before I could give it a little gas without the engine choking again.
    This bike has 13,500 kms on the clock, and had its 10,00 kms (5,000 miles) service just a few weeks ago. And it always started instantly, and ran nice and smooth.
    What do you make of that? Humidity? Bad fuel? Plugs? Only 3 weeks of storage.
    Thank you.
    Registered User waxrash's Avatar
    Jul 2011
    Garner, NC
    Was it stored on the center stand or side stand? Mine will do that every time if left on side stand for a few days. Dealer says oil collecting in left cylinder soaking plug. Can't validate that, but it never happens on center stand.
    Lynn
    2008 BMW R1200RT (most fun you can legally have)
    2002 BMW R1150RT
    2008 Kawasaki Versys
    May 2010
    Quote Originally Posted by lbarbee View Post
    It's on the centerstand. I'm a bit baffled by your dealer's remark. I am not very mechanically inclined, but how on earth can oil go INTO AND UP (or maybe down) the STILL cylinder, past the rings and all the way up the the combustion chamber and foul the plug? If that is possible, then there is a leak in the pistons' tightness, and many different symptoms would appear before a foul plug.
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Quote Originally Posted by Hammam View Post
    How cold was it in your garage? If on the cool side did you give it a bit of throttle when trying to start?
    Oil is splashed onto the cylinder walls "below" (the crank side) of the piston It is the job of the oil scraper ring to remove excess oil as the piston moves toward the crank on intake and power strokes. Imagine the engine stops with the piston closer to TDC than BDC. Any oil on the cylinder walls in the crank side of the piston will congregate at the bottom of the cylinder. If the bike is on the side stand the cylinders are not parallel to the ground. The small amount of oil on the left cylinder will pool toward the piston. Piston rings move. If the ring gap happens to be near the bottom of the piston the oil can migrate through the rings into the head. If this set of events happens on a dual plugged bikes the bottom plug is likely to become oil fouled.
    May 2011
    At the risk of being CRUDE, RTFM. (read the manual)
    It says turn the throttle a little for cold start.
    Try it.
    Its what my 2112 needs.
    David
    jeepinbanditrider
    Drain the fuel and refill with fresh stuff. Ethanol fuel is total garbage and can still go bad even with stabalizers in it. To me this sounds like your most likely culprit.
    Remeber fuel, air, spark. If you have all three the bike will fire. If one is bad or intermittent you will have issues.
    You're getting spark because the bike will run (albiet reluctantly) and short of a mouse or rat building a nest in your airbox (been known to happen), you have air.
    Edit- I'd pull the plugs also just to check them. They aren't hard to get to so should be a quick job. Just make sure they aren't fouled or oil soaked or anything weird like that.
    May 2010
    Try it.
    David
    Like you said, crude. Maybe the F was one letter too many. That being said, I READ the manuel, though I failed to learn it by heart to be able to recite it from memory in all circumstances. And I did crank the throttle, at the second attempt.
    Thanks.
    May 2010
    It's at a constant 55-60 F. Yes, I did give it a little throttle. At the second attempt. But then, I dit it again several more times, which may have compounded the problem. In my 6 years since I took up riding again, I've never had a bike (all BMWs) that wouldn't start readily, even on days around 35 F.
    Thank you.
    May 2010
    Very interesting and informative. Thank you.
    Jul 2011
    Garner, NC
    Sorry I can't explain. He seemed to understand, he described it precisely, I just can't remember his answer. All I can say for sure is storing on the side stand was the cause. Once I stopped, it stopped. It was scary the first time, hard to start, awful noise, entire bike shook, stalled several times. I thought I had a serious mechanical failure. That was 30,000 miles ago, no problems since.
    Bike always maintained at regular service intervals.
    I called the dealer tech from my driveway, he immediately said "did you have it stored on the side stand". Which I did.
    He said run it up the road an in 2 miles it'll be fine. He was right.
    I wish I had a more technical answer. Maybe oil draining down from the oil cooler?
    I am sure someone more intimate will have answer.
    Lynn
    2002 BMW R1150RT
    Jul 2011
    Garner, NC
    A quick search shows this debate in almost every major forum.
    I offer my answer as completely anecdotal. Two things I was told to do, store on center stand and full of fuel (or empty) due to fuel strip failures.
    I am just dumb enough to listen.
    Haven't had either problem since. Of course this proves little.
    Lynn
    2002 BMW R1150RT
    May 2010
    I don't think you're dumb, because, of course, your mechanic could be right. But I'd love to understand the details of it. That being said, my bike is on the center stand.
    Capt Pat
    Thank you.
    Sounds similar to an issue I had due to ethanol in the fuel, it collected enough water to rust up the fuel pump. It would crank all day but not start as the canbus sensed a FP issue and cut the power to the FP. Ended up replacing the FP and both injectors. BTW I used Stabil as well. Hope you have a better experience.
    R1200RT Artiee's Avatar
    Jul 2008
    Northern Virginia
    I'm not sure I can add more to what is already posted. My 2005 RT has never sat unused more than 5-7 days since I've had it. I ride year round to include commuting to work during the winter. The motorcycle sits outside in the parking lot overnight. Coming out in the morning after a night shift, temperatures have been as low as the low to mid 20's. It's sometimes been slightly sluggish but always fired right up on the first or second try.
    Experience IS NOT the best teacher! Someone else's experience is the best teacher.
