Results 1 to 13 of 13
Thread: 2007 R1200R Canister removal
    Jul 2007
    Bowie, MD
    Is there a thread on how to jumper out the canister that sits in front of the front shock? I need to set up new pair of shocks and it sure would be nice to have that out of the way even if temporarily.
    Jul 2007
    Bowie, MD
    OK, I assume this is too touchy of a subject. I did a google search and found several posts on how to do this along with a lot of controversy as to whether this is good for the environment and against the law etc. I really just want to get it out the way to play with the top preload nuts without the can in the way. Hope I didn't dredge up a sore subject and I apologize for that. I just put in a rebuilt ABS module and need to road test the bike so I put the canister back on. I'll pull it out later when I set up the shocks.
    Camas Valley Oregon
    I suggest you do a search on "cannisterectomy" there are instructions available. It's your bike do with it what you want. Don't worry about the "greenies" as every mile you ride decreases your impact on the environment as opposed to driving those same miles.
    Oct 2009
    Torrance CA
    I would save the canister though. Some states are rumbling about smog checks for motorcycles, at which point you will need it. They keep threatening us here in California. Just my 2 cents.
    1988 K75 Low Seat
    2009 R1200R Roadster
    Jul 2007
    Bowie, MD
    Thanks, I saw the term "cannisterectomy" out there. I guess I should have added the word "removal" to my title. I'll go back and read those. Hopefully it will point me to the right size hose fittings to use or I'll pick up a assortment. Its not too many lines. I'll save the canister
    cheers, Fletch
    Barback King rapiddog's Avatar
    Jan 2004
    Acton, SoCal just West of Hell
    where did you find the cannisterectomy thread? Linky?
    "...the burble of my exhaust unwound like a long cord behind me. Soon my speed snapped it, and I heard only the cry of the wind...." Larry of Arubia
    Jul 2007
    Bowie, MD
    Rapid dog, try searching using R1200R canisterectomy, note one 'n'. I sent you a PM with the one I used.
    Fletch
    Dec 2009
    Huntington Beach CA
    Other than access to your front shock, why would you want to eliminate the charcoal cannister? Does it affect the performance or driveability?
    Jul 2007
    Bowie, MD
    I have read from others that if the canister fills with fuel from over fill or tip over, the contents of the canister gets sucked into the throttle body and burned through the engine. This does not sound like a good thing.
    BTW, your sig says you live in HB. The canister is required in CA, just so you know.
    2011 R1200RT ka5ysy's Avatar
    Oct 2006
    Prairieville, Louisiana
    Here ya go, complete with diagram of the system. You might also want to join the RR group. Lots of great information on the bikes here too:
    http://www.r1150r.org/board/viewtopi...canisterectomy
    MSF #127350, Instructor, Louisiana Dept of Public Safety
    Motorcycle Safety, Awareness & Operator Training Program
    NAUI Instructor #36288
    Dec 2009
    Huntington Beach CA
    I don't think I'd remove the cannister myself. How high is too high when filling that might cause fuel to get into cannister? I've been filling about half way up the tube inside top of tank.
    Quote Originally Posted by fletchdude View Post
    That was common on R1150 series bikes where the canister was located lower then the fuel tank (much lower).. on the R1200R the canister is located between the fork tubes at about tank level (perhaps a bit lower).. and I haven't heard of any of them doing this.
    FWIW - the canister is a US/Canada only addition. It is not on bikes sold in Europe last I checked.
    Jan 2004
    ...I think what's meant is really over-filling and incase of a tipover the excess fuel will go into the can as opposed to on the ground.
