Results 1 to 4 of 4
Thread: New improved final drive 2013
    Registered User BlackdogGS's Avatar
    Sep 2010
    Zillah WA
    I've owned many BMW's including a 2005 GS and now a 2010 GS. I have never experienced any FD failures. The 2005 had 50,000 miles on it when I sold it and the 2010 currently has 40,000 miles. Even if I did have an issue I'd probably fix it in my garage and press on. I do however think that any final drive should last 150,000 miles without a problem. My question is: will the new water cooled boxer be fitted with a more robust FD?
    Sep 2008
    Wilmington, NC
    A bit hard to know right now.
    At least the failure modes of the current big hole drives are known so when enough design detail is known an educated guess might be possible- but it would still be only a guess. We known the side is flipped so that means different parts. Then there is the info re bearing sizes and fits but even if you have it all, you still don't know about supplier parts quality or assembly quality.
    Theory is nice but 5 yrs of road use of the produced fleet will tell the tale.
    Sheboygan, WI
    Cool
    Sep 2006
    Quote Originally Posted by racer7 View Post
    The flipped drive has been on the Wedge K's since '05 and seemingly less reports of issues.
    The internals may change...but only BMW AG knows that info it seems as part numbers don't tell the story.
    Steve Henson
