Results 1 to 3 of 3
Thread: 600 mile service
    Mar 2011
    socal
    600 mile service
    Have any of you done the 600oil change yet. My understanding their is 2 drain plugs, and uses the standard k1600 filter?
    Jeff Wilson life member 43362's Avatar
    Jun 2012
    Richmond Hill Ontario Canada
    Quote Originally Posted by t6pilot View Post
    Yes there are 2 drain plugs. One on the side, a black 17mm hex head beside the side stand which also has a filter that should be changed (more oil comes out of this than the oil drain plug than on the bottom of the pan), and a plug on the bottom of the oil pan. If you go to http://www.webbikeworld.com/bmw-c-650-gt/blog.htm there is a picture of the location. Yes it is the same filter as a k1600 or the r1200gs
    Jeff
    A bad day on the C650 GT scooter is better than the best day at work
    Mar 2011
    socal
    43362
    Thanks for update,
