Results 16 to 21 of 21
Thread: Long Range Planning for Alaska
    jeepinbanditrider
    How much previous motocamping have you done?
    Schwetzt du aa Deitsch? deitscher's Avatar
    Oct 2006
    Central PA
    Reply to Downs Question
    Hey Downs,
    I have done a lot of Moto Camping. Camped as we rode cross-country and on our trip to Newfoundland. Have good gear, not sure if we have all the gear we would need for Alaska though.
    -Doug
    Doug
    2009 F800ST
    172526
    Jul 2012
    Just ahead of a flat line
    Saw this on Amazon Canada today should be available on the US site too.
    http://www.amazon.ca/dp/0982310110/r...0_pd_re_dt_dt3
    Aug 2011
    Fairbanks Storage Question
    [QUOTE=Norwood;849462]Lot of good information here already....
    ..... store as much as you can in Fairbanks and travel lite up the Haul Road....
    Is there a dealer where you can store gear or did you rent a locker at a bus station?
    Prefers to play martinph's Avatar
    May 2005
    Armstrong, BC
    Quote Originally Posted by garthw View Post
    If you hit wet times up to Prudhoe you will want to have at least some sort of aggressive type of tire to deal with the slippery calcium "snot". We used Heideneu K60 and they worked well for bboth highway and gravel. They are a bit noisy at certain speeds but they stick in the wet and wear well. I had over 25,000 km (15,000 miles) on mine when I changed it.
    Did you really get that Mileage out of a set of Heideneu?
    Martin. BMW MOA Ambassador.17748
    BMW MOA Charter, Life member.
    Valley BMW Riders. British Columbia.
    172526
    Jul 2012
    Quote Originally Posted by martinPH View Post
    Yes I actually traded out the rear at 20,000k because I got a deal on a tire at Pacific Motorsports, but I am still running the front with 25,000 on it. I am sure I could have easily got another 5k out of the rear. That 20,000 includes a lot of gravel roads including the up and back of the Dempster.
    Will likely switch the front in the spring. My friend on his 1200GS is still running one with 25,000 on the rear but I would not be taking that tire anywhere risky now.
