Results 1 to 15 of 27
Thread: HID Lighting Supplier 2011 R1200RT
    Registered User zenduddhist's Avatar
    Mar 2012
    Looking for an HID Conversion kit for my R1200RT. I know that a lot of members have used the 1offmotorsports products, but they are no longer in business. What other vendors do you all suggest?
    Thanks,
    Chris
    1969 Triumph Bonneville T120R, 1972 Commando 750, 1974 Vespa Rally 200, 1974 Commando 850, 1975 Commando 850, 2010 Triumph T100 w/sidecar, 2011 BMW R1200RT, 2013 Honda CB1100
    Braintree, MA
    I use ebay for HID lights. You might or might not need to modify the low voltage harness (I'm an electronic tech). If you're looking for something that is plug and play, someone else will have to answer.
    Salty Fog Rally 2007, 2009, 2011, 2012, 2014 AND LOOKING FORWARD TO 2015!
    -Tom (KA1TOX)
    Rider on Ramald
    Jul 2007
    Saint Louis, MO
    I'm very pleased with my HID 55w slim-lines from DDM Tuning on a 2011 R1200RT (replacing both low-beam bulbs)... no Canbus issues. Great price ($40 / pair).
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    Quote Originally Posted by IDisposable View Post
    What temp bulbs did you get?
    My Motorrad
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
    Braintree, MA
    Quote Originally Posted by Ponch1 View Post
    4300K is closest to daylight. Higher numbers bias towards blue/violet, lower towards yellow.
    -Tom (KA1TOX)
    BinkleyLane binkleylane's Avatar
    Jul 2012
    Springboro, OH
    That is a great price. Tell us more. What was the install like? Can you. Do both low and high?
    B-est M-otorcycle (in the) W-orld
    Have Bike - Will Ride
    Jun 2009
    By the time you are done with harness and capacitor and mounting brackets they are more like $64.00 each
    I went with Yana-shiki 6K no purple, no blue! Bright & white. Been in for 2 years, Flawless and a 2 year warranty.
    http://www.yanashiki.com/product_p/hidh7-6k.htm
    All balllasts and bulbs are not created equal. The Yanashiki is what our local BMW dealer decided to stock.
    Jun 2009
    Quote Originally Posted by BinkleyLane View Post
    High beams are a no-no. HID's take a few moments to come to full illumination, hence impractical for High Beam.
    Try an Osram highouput 65W h7 bulb for high beam
    Rider on Ramald
    Jul 2007
    Saint Louis, MO
    I got a set of 8000K, then ordered a pair of replacement bulbs $15! as 6000K. Put one of each in the headlights... gets attention and gives me the best of high sign-reflectivity from the 8000K and better daylight-like light from the 6000K. I put the 8000K on the drivers-right side to pickup the signs.
    Rider on Ramald
    Jul 2007
    Saint Louis, MO
    Well, they're pretty typical, you pull out the current bulb and drill a hole in the back-housing.. then you pass a rubber grommet through the hole. This grommet has four wires in it, two connect to the OLD bulb plug to bring power back to the ballast, then then high-voltage goes back through in two other wires to a new bulb socket... the bulb itself is just as easy/hard as a normal bulb change. I zip-tied the ballasts together above & below the Y-yoke that supports the oil cooler.
    Basically procedure as the install in this video http://www.youtube.com/watch?v=Bs9guxU1tzY
    I did only the low beams. I DO NOT recommend using HID as high-beams since they have a brief light-off flash and a short warm up period for light to get to full strength. This would be bad for anything but the wide open areas where they can be left on... use a high-watt or LED for that.
    Registered User 185274's Avatar
    Nov 2012
    North Potomac, MD
    I'd be interested in how they actually function. From what I've seen, simply replacing the standard bulbs with HID bulbs creates excess throw. How do these function using the standard RT reflectors?
    Jul 2011
    Pawling NY
    I had HID's on my bike for the ride o Americade. Removed hem and went back to the stock bulbs in the hotel parking lot...................in the rain! Hated the light pattern. I actually like the stock bulbs better. Yes there is 'more' light with the HID's but it is better focused with the stock bulbs.
    Paul
    2011 R1200RT Traded
    2014 R1200RT fully optioned
    Braintree, MA
    Quote Originally Posted by sedanman View Post
    Whether an HID switch works well or not largely depends on the geometry of your reflector. It works great with my Vstrom, not so good with the Scion.
    -Tom (KA1TOX)
    Jun 2009
    Quote Originally Posted by MacRT View Post
    Work great in an RT!
    I am a bit puzzled by Sedanman's comments. I would NEVER go back to standard bulbs. Maybe he got some junk replacements or something seems amiss. The HIDs put out about triple the light at about 63% of the watts and I love the pattern! Go figure!
    As long as your headlight is adjusted properly, no flashes from on-coming!
    Jul 2011
    Pawling NY
    I'll try again if someone gives me a solid recommendation on which brand/part # to use.
    Paul
    2011 R1200RT Traded
