Results 1 to 7 of 7
Thread: 2008 R1200RT electrics question
    Registered User 5787's Avatar
    Sep 2012
    Larkspur, Colorado
    I have just acquired a 2008 R1200RT (CAN bus electronics), after decades of riding nothing but Airheads. I want to install a cigarette lighter - a real, honest-to-goodness lighter, not a cigarette type adapter.
    Can I connect a standard cigarette lighter directly to the battery (with an in-line fuse, of course) without interfering with, or damaging, the CAN bus electronics? If so, is there any advantage to the Powerlet lighter model AKT-002
    http://www.powerlet.com/product/ciga...er-element/455
    over a standard auto parts store lighter?
    Wilmington, NC
    Yes you can go direct to battery.
    Powerlet stuff is generally well made whch is more than one can say for a lot of the jnuk parts being imported from China and sold at many auto places these days..Plus they will make you about any wire length you want if you call..
    MOA #148075, BMWRO Shaun09's Avatar
    Mar 2009
    Eugene, OR
    Wiring accessories directly to the battery through a fuse (or through a fuse block to allow for more accessories - either always powered or switched with the ignition) is the way to bypass the CANbus.
    Powerlet makes nice products designed to withstand the current demands and moisture encountered on motorcycles. I suspect most accessories (like heated clothing) would require a DIN plug (BMW), coax, or SAE style. While many auto electronics would favor the cigarette lighter. The DIN style makes a more secure connection as far as I know.
    Cheers!
    Chris
    2009 BMW R1200RT (Shaun), 2004 MINI Cooper S (Gromit), 2006 BMW X3 (Wallace)
    Direct to the battery with fuse is fine for an honest to goodness lighter. Its use is light and shuts off automatically.
    No chance of drain on the battery. Hot (powered) when key is off.
    David
    Sep 2012
    Larkspur, Colorado
    2008 R1200RT electrics question Your Message
    Thanks for your responses.
    I have a related question: I have a heated vest that I have used for years on my old Airheads. There is no documentation for this vest. I have measured the current draw of the vest at approximately 3 amps. Theoretically this should make the vest useable with the bike's standard accessory outlets (rated at 10 amps maximum). However, I have no way to measure any potential "inductive kick" when the vest is plugged in or unplugged. I also don't know whether the CANbus is protected from such a kick, if one occurs.
    So, the question is: Is this vest safe to use with the bike's standard accessory outlet?
    Wilmington, NC
    No problem- will work fine.
    The 10A limit for your accessory circuit includes both outlets (10A total, not 20A) if you have a rear accessory outlet so won't support two sets of gear (rider and pillion). But you can run your jacket or vest plus gloves.
    na1g
    May 2011
    If you wire your cigarette lighter direct to the battery, the fuse should be as close to the battery as possible to minimize the un-fused portion of the wiring. Besides lighting-up your smokes (is that really what you are using it for?), the socket makes a handy place to plug in a battery tender.
    Happy New Year!
    pete
