Results 1 to 11 of 11
Thread: 2008 R1200GS - what is this plug ?
    Sep 2012
    Big Island of HI
    Below is a pic of a plug underneath the headlight assembly, behind the oil cooler. Anyone know what it is for? Thx - happy holidays!
    Registered User waxrash's Avatar
    Jul 2011
    Garner, NC
    Can't tell from the pic, but looks like the power connector for the factory GPS. If so you can buy the adapter at the dealer to wire up your gps. On my RT it sits right under the headlights.
    That's my guess from the picture.
    Lynn
    2008 BMW R1200RT (most fun you can legally have)
    2002 BMW R1150RT
    2008 Kawasaki Versys
    Jul 2011
    Garner, NC
    The only down side to using the factory GPS plug is that if you use a canbus smart charger, it turns your gps on when the canbus comes on. I remove my gps when in storage so no problem.
    Lynn
    2002 BMW R1150RT
    Sep 2012
    Big Island of HI
    Quote Originally Posted by lbarbee View Post
    I live on the Big Island of HI - if I need a gps here, then I should not be riding!
    Thanks for your answer. BTW, can the plug be used as a hot for other accessories?
    MOA #148075, BMWRO Shaun09's Avatar
    Mar 2009
    Eugene, OR
    Yes, if it's a low-current accessory. I used it (with a repair connector) as a trigger wire for a fuse bock (from Eastern Beaver) to power other accessories.
    This post gives the BMW part number (83300413585). (#1 lead=negative, #3 lead=12v positive)
    http://www.advrider.com/forums/showp...45&postcount=7
    Cheers!
    Chris
    2009 BMW R1200RT (Shaun), 2004 MINI Cooper S (Gromit), 2006 BMW X3 (Wallace)
    Jul 2011
    Garner, NC
    Hmm, wonder what the current limits are?
    Btw, shouldn't this be in hexheads/cam heads?
    Lynn
    2002 BMW R1150RT
    Mar 2009
    Eugene, OR
    Based on the size of the wire, it must be pretty low. 1 amp, maybe? Searching for GPS current draw suggests that the draw is less than an amp.
    Chris
    Vancouver, B.C. Canada
    You might get more info in the correct forum for this which is the Hexheads/Camheads.
    This Oilheads forum is for 2 Cylinder Oil/Air cooled Boxer engines up to 1150cc plus R1200C models, 1994-2005.
    Apr 2009
    Cincinnati, Ohio
    I once found a dangling connector like that on my '09 GS (after getting home from my first fuel strip replacement) and it turned out that it was supposed to be connected to the fuel tank breather valve (#6 in the diagram below). Will that harness reach around to the throttle side of the bike just inside the fairing?
    2009 R1200GS
    Sep 2012
    Big Island of HI
    Quote Originally Posted by wellston View Post
    Thanks for the idea - much too short. Comes out of the harness right behind the oil cooler. No length to wire.
    Apr 2010
    Western MA
    On my 2009 RT, there is a plug for the second horn wrapped on the clutch side of the nacelle's frame members. I retrofitted the earlier dual horns (replacing the single pancake) and used this plug for the second horn. I'm not sure if the GS also went from 2 horns to 1 pancake, but if so, this might also be a possibility...though the GPS connection may make more sense for the GS.
    Also, doesn't the GPS plug have three pins: positive, negative, and speed-sense lead?
    Theo
