Results 1 to 6 of 6
Thread: ESA Shock Abssorber dissambly R1200RT
    Nov 2009
    Kirkwood, Missouri
    I recently Purchased a set of lowering springs from Hyperpro for my 2009 R1200RT. I would like to install them myself and was wondering if anyone has done this job and if you need a special spring compressor. The spring compressor I have is a general unit that has worked on several shocks from different models. With only 24,000 miles on my RT I decided to go this route rather than new lower shocks.
    Have you talked to the vendor about what you're trying to do? I've never heard of "lowering springs".. if you put shorter springs on a shock, the full extension of the shock must be reduced to match if what you're trying to do is make a shorter shock.
    It's unclear how you're going about this..
    Nov 2009
    Kirkwood, Missouri
    The springs have a "built in sag" so when weighted you end up with a lowered ride height. EPM performance sells them and I have talked to Klaus several times and it sounded like it was worth a try because they are a reputable company. The cost is much less than going with complete shocks that I don't need.
    Smile
    I borrowed a spring compressor from the BMW repair shop near me. Changed the spring and returned the compressor.
    I plan on adding a 3mm shim to my front spring to adjust the preload for 35mm sag with me on the bike. I am building a
    spring compressor out of an automotive spring compressor for struts on cars. I have the shim made out of 304 stainless.
    I don't think you can do it without a compressor. I tried the automotive type and it is too big.
    I tried with banding No joy there too and it would have scratched the spring.
    I am sending my rear shock to a guy for a slightly stiffer spring. I can't do that one my self at all.
    Hi Dave,
    You'll have a hard time getting the spring off your rear shock. You can't take it off the bottom. You will find that it has a lot of pre load on a weak spring. A much stronger spring will less pre load will be much easier to control.
    Quote away.
    Thank you,
    Ed Sorbo, owner
    Lindemann Engineering, LLC
    909 838-4587
    Did I answer the question?
    Nov 2009
    Kirkwood, Missouri
    Just a follow up on the Hyperpro lowering springs. I ended up having the local BMW dealer break down the shocks and install the new lowering springs for about one hour labor charge when I brought the shocks to them. The springs work great and the ride is slightly improved, all the ESA functions work normally and I can get my feet flat on the ground. I can still get the bike on its center stand fairly easily and the side stand seems to be OK so far. It is much easier to move my bike around when backing into a parking spot or sitting at a stop light. After several rides I don't find any disadvantage for my mostly touring riding style.
    Sep 2011
    Western Massachusetts
    Wow, this is very interesting info. I'd like very much to lower my 2010 but the high cost has put me off. Can I ask what the cost was?
