Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 44
Thread: 2012 R1200RT 600 mi service with unapproved oil?
    Dec 2007
    Auburn, AL
    I know, an oil thread, but help me out. Three weeks ago I took my new RT in for the 600 mile service. I assumed that turning your bike over to the dealer for service would result in the service being performed as prescribed by BMW. A couple of days ago I was reading the owners manual and looked over the approved/recommended oils for my new bike. I noticed that, unlike my previous '07 RT, 20W-50 was not listed as an approved oil for the new engine. However, "4 quarts BMW 20W-50 bulk" is what was listed on the invoice as being installed in my bike. If 20W-50 is still ok for the newer engines, why would it not be listed in the owner's manual? And if it's not, shouldn't I have been advised prior to service that the dealer was going to install a product different than that which is recommended?
    Should I drain what was put in there and install what's recommended? Am I obsessing about something not really important? I just am concerned about starting the bike on 20 degree mornings with heavy oil since cold starting is the most wearing thing on an engine.
    So, change the oil? Or get over it. I have 400 miles on the oil but the coldest days are still coming.
    Charlie
    Auburn, Alabama
    Current - 2012 R1200RT, 2012 CBR250R, 2014 DL650 Adventure, 2013 PCX150
    Quote Originally Posted by crawfcj View Post
    I'd return the dealer with your handbook in hand and point out the error of their ways to them. Tell them to make it "right." You paid to have it done right, it wasn't, so they owe you. Plus it sounds as if they put dino oil in - I believe BMW now calls for synthetic right from the 600 mile service on the new engines..
    Lomita, California
    Most of the people I have talked to don't want to go with synthetic til 10 or 20 k miles on the bike.
    It isn't unusual to have to use near to spec oil, as the absolute might not be available at the moment.
    I don't think it really makes any difference.
    Of all the miscellaneous oils I have put in motorcycles, I don't think it ever made any difference.
    dc
    Dec 2007
    Auburn, AL
    Thanks for the reply. I'm leaning in that direction, Don. On the other hand, I'm not sure I want to engage in a fight to have it done right, when the trust is already gone. Do I really want them working on my bike?
    I would like to call or write BMWNA to have a rep advise me. Maybe that oil is ok (I doubt it). Anyone have a contact number?
    Charlie
    Auburn, Alabama
    AZ
    I would forget about it, myself, but Don has a valid point. You don't need to "fight" to make your point. Just stick to the facts and see where it goes. Their response will tell you if you should stick with them or not.
    Good luck man!
    MOA #107139
    RA #28511
    YB #2005
    Registered User gsinnc's Avatar
    Charlotte, NC
    Hmmmm.... check out his discussion .... sounds like BMW may be suggesting 20w-50 Synthetic
    http://bmwsporttouring.com/ubbthread...gonew=1#UNREAD
    Ed Apelian
    When Life Throws You a Curve Lean into it!
    2002 BMW R1150GS - (sold) Replaced with '12 R1200GSA Magma Red!
    2006 R1200RT- Granite Gray
    Lomita, California
    And also that the dealer, when confronted, said you could, also, if you want, use what's in the manual.
    In other words, it don't make doodly whit of a difference.
    dc
    Dec 2007
    Auburn, AL
    Quote Originally Posted by GSinNC View Post
    I followed that thread and the last post mentioned that BMW had indicated synthetic for the camheads, but nothing about 20W-50.
    By the way, here are the approved oils listed in the manual:
    Engine oil
    Engine oil, capacity max 1.1 gal (max 4.0 l), with filter change
    products recommended by BMW Motorrad and generally permissible viscosity classes
    SAE 5W-40, API SF/ACEA A2, or better ≥-4 ??F (≥-20 ??C)
    SAE 5W-≥50, API SF/ACEA A2, or better ≥-4 ??F (≥-20 ??C)
    SAE 10W-40, API SF/ACEA A2, or better ≥14 ??F (≥-10 ??C)
    SAE 10W-≥50, API SF/ACEA A2, or better ≥-4 ??F (≥-20 ??C)
    SAE 15W-≥40, API SF/ACEA A2, or better ≥32 ??F (≥0 ??C)
    Charlie
    Auburn, Alabama
    chris@cburtis.com
    Crawfcj,
    I just had my 2013 R1200RT in for the 600m service and also see on my invoice that they used 20W50 PETR DRUM. I assume it's the same as you had installed in yours.
    Dealer here is closed for the next few days. I'll likly give them a call next week.
    Any updates from your side would be appreciated.
    Chris
    Charlotte, NC
    Engine oil
    The very first post of that thread reads........My dealer informs me just recently that a recent BMW tech/service guide is now recommending full synthetic 20W50 for camhead engines and said that is what they will use at my 6K mile service coming up soon.
    Ed Apelian
    Dec 2007
    Auburn, AL
    I really appreciate all of the input you guys have provided. I've found the contact number and email for BMWNA and will write them to get their answer. I will share it here for all to see. With the holidays going on, I'll be surprised to get an answer before January, but we'll see.
    Charlie
    Auburn, Alabama
    Charlotte, NC
    That would be great since I have a 2012 R1200GSA that just had its 600 mile service so the response of BMWNA would be of significant interest to me!
    For what its worth at the 600 service they put in 10w-40 Dino oil. I have never used synthetic in any of my cars or bikes unless specifically specified in the owners manual. I change my oil way to often to benefit from synthetic .... just me being anal. But at the 600 mile service I specifically asked what oil they would use since I already have 2+ cases of 20w-50 Dino for use in my '06 RT. They made a point to note 10w-40 dino is what they use in all camheads.
    Keep us posted! Thanks!!
    Ed Apelian
    DeLand Florida
    My dealer also told me that they use 20W-50 oil in their bikes. My R1200R is running it, put in by them during the 600 mile service. Personally, I am not worrying about it.
    Jan 2011
    kentucky
    600 mile service
    I have a 2011 r1200rt one dealer says 10-40wt another 20-50wt,and the owner manual is confusing on this, would be interested what every one else is using,
    na1g
    May 2011
    Charlie, since you live and ride in ALabama where it isn't likely to get all that cold (like here in MA where it'll be a high of 35 today) I wouldn't think twice about the 20W-50. And if it's still in the bike when it gets hot again, you're all set. Note that 15W-50 is listed in the manual and (in my most humble opinion) I don't think those extra 5 W's will make any difference whatsoever.
    I can't speak to the synthetic/petro debate but I'm following the 10K on the petro plan. My RT is still using a little oil at 9K. At the 12K service I'll see what the dealer says.
    Happy Holidays, all! Lang may yer lum reek! (Scottish - it's a good thing, trust me)
    pete
