Results 1 to 3 of 3
Thread: Oil level question
    Registered User weeman's Avatar
    Oct 2012
    Near Bellingham, Wa
    Oil level question
    Hello all,
    I'm changing fluids on my newly acquired 1967 r50/2 and wanted to know how many cc's to file the final drive and swing arm? I'm using GL-4 85w90 as the current oil inside is not motor but hypoid.
    Also, can anyone suggest where to obtain a shop/owners manual from?
    Thanks to you all!
    Steve
    Administrator 20774's Avatar
    Steve -
    If you got two liters, you would be more than covered...that would even include the transmission. The final drive is a fill to the bottom of the threads. The driveshaft is 50-100cc...doesn't take much. The transmission is also bottom of the filler hole threads.
    Vech at Benchmark Works can hook you up with a manual. There manuals on line...they were all the same for the /2 models, with entries for each model during the period. Duane Ausherman and Jeff Dean have manuals:
    http://w6rec.com/duane/bmw/2man/index.htm
    http://bmwdean.com/1966-owners-manual.htm
    Oct 2012
    Near Bellingham, Wa
    Steve -
    Thank you thank you, that's a heck of a lot of help! I will contact Vech asap. Merry Christmas!
    Steve
