Results 1 to 14 of 14
Thread: Sidecar turn signals
    Sheep Dog
    Apr 2007
    South Central Indiana
    I know there's not a lot of sidecar guys on here, but, I'll bet somebody has an opinion. Do you unhook the bikes right hand turn signals when you have right hand turn signals on the sidecar? Restoring an R90/6 with a Velorex 562.
    Apr 2005
    Rapid City South Dakota
    Yes!! I have followed rigs that had right signals on the bike and the car and it is confusing. My rig is is set up with the bike signals disconnected.
    Harold In Rapid City, SD
    1985 K100RT Bullit
    1985 K100XX/EML Bemel
    TravelsWithBarley.com
    Jan 2009
    Craftsbury, Vermont
    I wrapped the right turn signals with electrical tape for a couple of months, but the sidecar turn signal is mounted forward of the trunk a few inches and was not always visible to vehicles behind me (depending on the angle of view), so I took it off. Figured it was better to get their attention even if there was some confusion on their part.
    Pete
    '12 R1200GSA for solo rides
    '10 R1200GSA with Hannigan dual sport sidecar for rides with Tulliver
    On the Road
    Aug 2006
    Ocala Fl
    Sidecar/Bike turn siginals
    Quote Originally Posted by rcockrum View Post
    No.I run with the bike right and the sidcar right turn siginals.Front suidecar siuginal is blocked by a toolbox.I run an 83 R100RT & 2005 562.
    Jack
    Ocala Fl
    SW Ohio
    My Ural came without right side signals on the bike. I agree, having the on the car and the bike would just be confusing. Could easily be mistaken for 4-way flashers.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Astatula, FL
    I also have disconnected the right side signals on the bike. I guess it will depend on the visibility/mounting of the lights on your hack.
    Bob Weis
    '04 K12RS - Hannigan Hack
    That road looks good! Norwood's Avatar
    Aug 2005
    From NW AL to WNC
    Right side on my R90/6 is disconnected.... same sidecar as yours..
    MOA Ambassador, Member of AL, GA and Chattanooga Clubs, MTF Gold member and BOD.
    2011 R1200 GSA (My Radio Flyer) 75 R90/6 with Velorex sidecar
    My annual charity event: http://www.echbenefit.smugmug.com/
    " Oh Lord I pray, Let me live long enough to do everything they say I've done"
    Depends on local laws, I origanally disconnected the right side turn signals on the bike, but then it wouldn't pass inspection. For a few years I'd reconnect to pass inspection, then disconnect, but the last couple years I've just left then connected.
    Mike Currin
    93 K1100RS / EML Speed 2000 sidecar
    06 Ducati ST3
    67 Triumph 650 Chopper
    No longer a member here
    Same here. No right turn signals on bike. However, the front right was little tricky. Rear turnsignal is incorporated in taillight on sidecar fender but front turn signal had to be added.
    Waitsfield, VT
    My Sputnick has a top of the fender signal which I energize in place of the right rear light on the bike (F650). Seems less confusing to followers. The right front signal remains functional, as it was easier, and I figure the attention it may get from anyone trying to turn with me, or in front of me, helps a little. Besides, it's easier to just switch the rear lead and leave the front alone. I've not had an inspection issue, but I'm not sure how close they look, as long as something is flashing.
    Weeble
    Sheep Dog
    Apr 2007
    Thinking about using a trailer wiring harness and just removing the right side turn signal bulbs on the bike. The R90/6 signals are not also running lights.
    Figure I can tap into the bike lights anywhere.
    Jun 2008
    Oregon
    right turn signal
    On my R1100 that I bought used the signal on the bike is disconnected. With the wide EZS car, if it were not, I think it would definitely look like four way flashers. Too many cage drivers are all ready confused just driving their cars. I wouldn't want to add any more to their confusion.
    Aug 2005
    Charlotte, NC
    Bike right rear turnsignal
    works on my wifes airhead with Velorex sidecar.
    The bulb was removed from the turnsignal on her R1150R with EZS sidecar.
    Enjoying the ride, but always on the alert for a rally.......
    Mar 2012
    Riggins, ID
    Signals andBrake - Visibility
    My dirt hack is based on a R100/7, pretty well stipped down with a Heddingham front end, two into one Supertapp, solo seat and the chair build from a California sidecar frame, modified. I left the stock front signals on the bike in place, with no wiring to the right signal, and incorporated the rear left signal in the brake light. Also added Hyperlites for visibility. On the chair, I have a steel fender with turnsignals, running and brakelights for the right side mounted. I agree that not disconnecting the right turn signals on the bike could confuse the issue especially in adverse visibility conditions (at night, foul weather, oncoming traffic).
    Gary Phillips - #6322
    Wildland Firefighter, Retired, Riggins, ID
    Heartland Moto Locos BMW Riders
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '00 R1100RS
