I guess I'm looking for a little hand holding. I've read Snobum's and Anton's info on changing the oil filter for my 1995 R100 GSPD. From what I understand the paper gasket should not be used, just the shim, black and white O rings. But, I found the paper gasket in addition to the shim, black and white O rings when I took it apart today. Should I put it back the way it was with the paper gasket or, not use the paper gasket?
