Page 8 of 10 FirstFirst ... 6 7 8 9 10 LastLast
Results 106 to 120 of 137
Thread: 1978 R100/7 Topend Overhaul
  1. #106
    Jun 2007
    Minneapolis, MN
    Love what you're doing & sharing Kurt.
    As I'm reading all the detail and care you're putting into re-assembly I had a thought about how the employees at BMW put the engines together - probably for them 1-2-3 next 1-2-3 next.
    At any rate, looks like great progress Kurt.
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
  2. #107
    Let's see if I can't bring this to a conclusion! The dynamic duo (w/ Bill) got to work again yesterday. I had already installed the oil pickup with blue loctite on the bolts and remounted the oil pan. I rechecked the head bolt torque after sitting for a week...some of the bolts need a bit more torque. I backed them off almost a quarter turn and ran them back up to 25 ft-lbs. I set the valve clearances at 0.15/0.25mm intake/exhaust...a little looser on exhaust until things settle in.
    This was the critical point. I needed to spin the engine to ensure that I had oil flow to the rocker blocks. I secured each spark plug to the top of the cylinder using rope as shown. I wish I had binder clips like shown in another thread...I'll have to remember that...but the rope worked fine. I cranked for 3 days...OK, it was more like 30-40 seconds. Finally got some oil to both rockers. I didn't know what to expect, but it looked good enough. Once that was done, I could put on the valve covers and move on to the exhaust system.
  3. #108
    Got the headers all set up. Put the exhaust nut on first, then the compression ring and split ring. Coated the exhaust threads with anti-seize...I used the nickel variety which is good to 2400 deg F. The headers slipped in and the nuts screwed easily...put the rest of the exhaust system in place. Then went back to the front and began tightening all connections, tweaking things as we went. The clamp on the left side at the header/muffler connection was impacting the action of the sidestand, so I had to rotate it a bit for clearance.
    Excuse the dirty valve cover! I'll clean those up the next time they're off for retorquing.
  4. #109
    We got everything place...mentally going over the steps and nothing seems to have been forgotten. Here's a picture of the new cylinder. Interesting color combon with the very bright cylinder, duller refurbed head, and dirty valve cover. I'm sure over time, the color will even out. She was ready to roll!
  5. #110
    She Lives!!
    Initially, I hadn't planned on riding because the weather was supposed to be messy here (hey! we got some rain! ) But we finished somewhat early, the sun was poking out. I'm going for a ride!!!
    Got suited up. The next moment of truth!! She started, took some coaxing...the last time I rode the bike was in December. Finally got some throttle response and held the RPMs at around 3K for 60 seconds...a very long period of time! Smoke was roiling off the exhaust nuts. Kind of weird doing that. Threw a leg over and went for about 20-25 miles. Bill followed in the car as I made my way to a gas station.
    I got to say, I've very pleased at this point. The bike sounded fine after the initial start. A little extra valve noise due to the wider exhaust clearance. I can really feel a change in power level. It accelerates very nice. It seems smoother, but I haven't done anything to the carbs and will have to resynch them. I tried not to dwell at any speed for very long, going up and down on the throttle and getting some back pressure in going downhill. Bill said he didn't notice any smoke when rolling off the throttle.
    So, on with the break-in. I'll drop oil and change filter at 50 miles...a bit extreme but I just want to get that out of there. I'm running 10w40 right now and will switch to 20w50. I'll also check valves and head torque. I should also go over every nut/but that was removed just to be sure that everything is staying tight. I'll change/check everything at 500 miles...hopefully the settings will be stable.
    Thanks for reading along. No real drama along the way. Having an extra pair of eyes didn't hurt either!
  6. #111
    Jun 2007
    Minneapolis, MN
    Congratulations, Kurt - you took this project one step at a time & I liked your decision process along the way - nice looking machine!
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
  7. #112
    Thanks...I guess the proof of the pudding is in the eating! Or in this case, a nice ticking machine!!
  8. #113
    May 2008
    B.P., MN
    Congrats on taking the dive for those trick new cylinders/pistons and the finished product. The thing I can never wrap my mind around when handling a piston before installation, is how can these slugs moving, what 3000 odd feet per minute?, come to two complete stops while changing direction, and going the other direction, without flying to bits? Or is it 3000 feet per hour? Anywho, it seems physically impossible.
  9. #114
    DeLand Florida
    Nothing like knowing the job was done right because you did it. Enjoy the many trouble free miles this will bring.
  10. #115
    I probably won't be able to really relax for at least another couple of thousand miles! I always have this nagging wonder...what did I forget or not do right. Anyway, I'm loving it so far.
  11. #116
    Vancouver, B.C. Canada
    Awesome job and a great rebuild thread Kurt. Really enjoyed following this one.
    Enjoy your pudding!
  12. #117
    Houston, TX or Portland, OR
    I feel ya... I did mine more than 7 years ago and I still get that nagging feeling...
    I'm sure it will work out great- nice pics of the job as well.
    Jim
  13. #118
    #4869 DennisDarrow's Avatar
    Sugar Valley, Ga
    Roll on Roll ON............Good job and just as expected from YOU it is running great.............God Bless.....lol.......HE is with you Bud........Dennis
  14. #119
    Dec 2009
    Huntington Beach CA
    I'm curious after reading your article on oil, what type are you going to be using?
  15. #120
    Quote Originally Posted by jbarneshb View Post
    I'm starting with BMW's petro 10w40...it was suggested by Ted Porter, probably more for what he thought might be colder temps. My first oil change I will go back to BMW 20w50. At some point in the future, I'll switch to Spectro 20w50.
