Results 1 to 10 of 10
Thread: Valve clearance 2009 RTP?
    Registered User kdeline's Avatar
    Gurnee IL
    Civilian model settings are 15mm intake, 30mm exhaust. Why is the authority engine 35mm exhaust? It's the same engine. Since I will not be riding it like a cop can't I just set it at 30mm? What is the reasoning behind this?
    #13338 PGlaves's Avatar
    I don't know. My guess is it relates to being parked, idling. As was the oil cooler fans.
    Gurnee IL
    So I should be able to set at 30mm?
    May 2011
    I would stick with the spec.
    I do not know way its different.
    David
    Gurnee IL
    David
    I question that since the bike will no longer be used as a police bike, no long idling, parades, traffic stops, etc. So will I need to set it as a normal civilian bike and if I do not, will I be asking for problems down the road? As far as I know there is no difference in the motor.
    What is the source for the .35mm spec?
    The bigger gap provides longer closed time and better cooling of the valve head by conduction to the valve seat. It also might affect the exhaust flow. I say might because I don't know where the most restrictive element in the entire flow is.
    Also, the critical thing is that the valves are set the same side to side. Given the published ranges for shim set valves on other models, I suspect .30 v .35 doesn't make a huge difference in running, although it should make a difference in valve head cooling. I'm not at all sure what that extra gap translates to into milliseconds of closed time but it is certainly some more closed time.
    Gurnee IL
    From www.bmwmc.net.
    Whats new tab.
    This is a Police motors sight.
    05/24/2011
    Technician Maintenance Notes: Please take note that the exhaust valve clearance on 2006 - 2009 R1200RT-P models (which all include option code 369) is different than the civil version - special service motors should have exhaust valve clearance set at .35 mm (civil models are at .30 mm). Please ensure that your technicians are following this recommendation from the RSD Repair Manual CD. Also, the Service Data is listed in full under technical information / checklists / R 1200 RT-P / Service Data.
    Quote Originally Posted by kdeline View Post
    From www.bmwmc.net.
    Whats new tab.
    05/24/2011
    Thanks. It sure would have been nice if they had included "due to extended idling" or "due to different valves", or "due to xxx..." as an explanation so folks weren't left guessing as to reasons - but BMW almost never explains their reasons.
    I would look up the part numbers for the exhaust valves. If they are the same then I would be comforable using the .30mm civilian specification, but don't really have a good reason why I would necessarily want to.
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Note that this difference of 0.05 millimeters is equal to just a hair less than 0.002 (two thousandths of an) inch.
    We know from past experience that BMW has often spec'd valve clearances a bit on the tight side, and loosening them up a little often makes them run a lot better (intakes AND exhausts).
    Gurnee IL
    I tend to run my valves at a very lose 15 and 30 as I stretch my maintenance intervals. They just never change that much.
