Results 1 to 11 of 11
Thread: GPS Mount Advice
    Apr 2012
    Gilbert, AZ
    GPS Mount Advice
    Maybe this should be in the Gear forum but it is airhead related.
    I'd like to use my Garmin nuvi on my R100RS. I've found several mounts that clamp on the handlebar but since there isn't much handlebar real estate on the RS I don't know if they'd work very well...I'm not sure where they could attach. Anybody have any advice for a suitable mount for my bike? It doesn't have to be waterproof...I don't ride in the rain...but I'd prefer it didn't fall off. And it'd be nice if if was relatively inexpensive, say < $50.
    2004 R1150RT
    BMW MOA 181289
    Earache
    If the brake fluid reservoir cap is held on with screws, (rather than the screw on type), I can make you a RAM ball mount holder for it.
    The part I'd make would be free of charge, RAM balls and a clamp arm would cost less than $50 easily.
    Would look similar to this GoPro mount I made...
    Or you could mount off of the clutch or brake lever perch like this...
    Nov 2009
    Central Ontario, Canada
    I have a zipper case with a ram ball on the back, it does a good job. No longer use it as I invested in a Montana 600 GPS that is weather proof and has a good ram mount. I will post a picture later this evening and if you want it I can post it to you. In fact I have two of these, bought in Europe.
    1987 R100RS
    1981 R80G/S(wp4860 forks, Henderson triple clamp)
    2010 Husaberg FE450
    Past BMWs: '68 R50/2, '77 R80/7, '87 R80GSPD, '76 R60/6, '85 K100RS, '91 R100GS
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    Earache, I sent you a private message.
    Earache
    Reply sent!
    Nov 2009
    Case discussed
    1987 R100RS
    2010 Husaberg FE450
    Nov 2009
    For mounting to the handlebar/bike ram has many options, here is the link to their site
    http://www.rammount.com/
    1987 R100RS
    2010 Husaberg FE450
    advrider.com
    Oct 2005
    For my Garmin zumo, I use a Ram mount off the very slight "rise" portion of the handlebar. It's not in the way of the cables, wires, or speedometer (even though it negates the use of the latter). I hard-wired an inline-fused connection along the frame under the tank to the battery.
    Now, I just need a Ram mount for each motorcycle..
    Rally Rat tvrla's Avatar
    Oct 2004
    Portland, Oregon
    I used to use a ram mount off the mirror mount on the perch on my 77RS.
    It worked ok, but I wasn't all that pleased with it.
    Then I came up with a simple solution - a piece of stainless sheet bent at a right angle, and attached via the three screws clamping the gauge pod. The Garmin mount is then screwed to that piece of stainless. It's simple and works great!
    May 2012
    VA
    I used the ram mount pieces from the automoto kit. I bought the kit at gpscity.com. It worked out very well and bolted right on:
    Stan
    AH# 13238
    Apr 2012
    Gilbert, AZ
    My Solution
    Thanks for all the replies.
    I got one of these off eBay:
    Sorry for the small picture size, it looks bigger on PhotoBucket.
    I mounted it to the dashboard in a hole left by a PO:
    Here's how it looks with the GPS in place:
    It blocks the voltmeter but works fine and was an easy inexpensive solution. I may try moving it to a spot that leaves the voltmeter viewable. I also need to rig some kind of a sunshade for the GPS, tho.
    The holes in the right side of the dashboard were where the PO had mounted some fuse holders. I think I can find some plugs for them. The toggle switch is a four-way flasher mod, again from a PO. Jeez...looks like the bike needs a bath. I didn't realize it was that grungy until I looked at these pics.
    Anyway, that's what I came up with. Sorry for the picture quality.
    2004 R1150RT
    BMW MOA 181289
