Results 1 to 11 of 11
Thread: GPS Mount Advice
Hybrid View
    Apr 2012
    Gilbert, AZ
    GPS Mount Advice
    Maybe this should be in the Gear forum but it is airhead related.
    I'd like to use my Garmin nuvi on my R100RS. I've found several mounts that clamp on the handlebar but since there isn't much handlebar real estate on the RS I don't know if they'd work very well...I'm not sure where they could attach. Anybody have any advice for a suitable mount for my bike? It doesn't have to be waterproof...I don't ride in the rain...but I'd prefer it didn't fall off. And it'd be nice if if was relatively inexpensive, say < $50.
    2004 R1150RT
    BMW MOA 181289
    Earache
    If the brake fluid reservoir cap is held on with screws, (rather than the screw on type), I can make you a RAM ball mount holder for it.
    The part I'd make would be free of charge, RAM balls and a clamp arm would cost less than $50 easily.
    Would look similar to this GoPro mount I made...
    Or you could mount off of the clutch or brake lever perch like this...
    Nov 2009
    Central Ontario, Canada
    I have a zipper case with a ram ball on the back, it does a good job. No longer use it as I invested in a Montana 600 GPS that is weather proof and has a good ram mount. I will post a picture later this evening and if you want it I can post it to you. In fact I have two of these, bought in Europe.
    '81 R80G/S(wp4860 forks, Henderson triple clamp)
    '10 Husaberg FE450, '10KTM 250XC-W
    Past BMWs: '68 R50/2, '77 R80/7, '87 R80GSPD, '76 R60/6, '85 K100RS, '91 R100GS,'87 R100RS
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    Earache, I sent you a private message.
    Earache
    Reply sent!
    Nov 2009
    Case discussed
