Results 16 to 30 of 35
Thread: Best TB sync tool?
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by JConway607 View Post
    I am curious, though, how BMW changed the engine in the later models to lower the vibrations.
    A counter balancer added to the rear end of the auxilliary shaft driving the oil pumps and cam chains.
    Mark Neblett
    Fairfax, VA
    #32806
    Riding where it's hot! AZ-J's Avatar
    Mar 2007
    Scottsdale, AZ
    I ordered the Harmonizer via PayPal. Anyone want to buy a hardly used TwinMax?
    My bike shown here
    Jordan M, MOA #24434
    My Blog
    Mar 2009
    Quote Originally Posted by mneblett View Post
    but that doesn't mean there aren't consequences from long-term exposure
    Do you have any data regarding health consequences to professional and do-it-yourself motorcycle mechanics arising from the use of mercury sticks?
    JohnWC
    Akron, Ohio
    What model and year did BMW go with those changes?
    Vancouver, B.C. Canada
    Quote Originally Posted by 141987 View Post
    It's interesting that we used to play with mercury when we were kids and none of us died from it as far as I know. Today it is cast as one of the worst poisons ever. If ingested internally I would imagine so but I take these things with a grain of salt.
    I've used mercury sticks, home made balancers, the Morgan Carbtune, the TwinMax and the Harmonizer to synch 1100 bikes. I've found the Harmonizer to be the best of the bunch by a wide margin. It's accurate, easy to use and I've checked it against the expensive BMW shop tool with good results.
    I also really like the fact that I can hook it onto my windshield and ride the bikes around the neighbourhood to check my handy work. Try doing that with mercury sticks!
    Nov 2005
    Fairfax, VA
    2005 R12's -- the hexheads.
    Mark Neblett
    Fairfax, VA
    #32806
    Diamondhead, MS
    How about data about nurses and doctors using mercury manometers for taking blood pressures. I haven't noticed a lot of those folks falling over dead.
    Registered User twinsig's Avatar
    Apr 2012
    Heart Of Dixie!
    Found the vibration moves around some. My current state of tune smooths out the vibes at 3500 (70 mph in 6th). And the kind officer reminded me of that last night while traveling through a 55 zone.
    He let me go with a verbal warning (and watch out for the deer), i wished him a merry Christmas.
    I wonder. If been on one of those LOUD twins would he have done the same?
    Democracy is two wolves and a lamb voting on what to have for lunch
    Liberty is a well-armed lamb contesting the vote
    Registered User JoshuaTree's Avatar
    Jan 2011
    Austin, Texas, USA, Earth, SOL, Western Spiral Arm, Milky Way Galaxy
    Lightbulb For those of us with uncertain gravitic anomalies in the garage...
    (i.e. I drop 'stuff' sometimes)
    I wound up with a refurbished Kowa Tools KEK-55 (the original version, with the vacuum tube ports on the back of the unit). It's done a credible job so far (now 10+ years), and usually checks close enough to the factory BMW Synchro.
    Josh Friedman
    "Quis custodiet ipsos custodes?"
    "... Love Much, Laugh Often..."
    the Wizard of Oz 26667's Avatar
    Jul 2006
    NW suburban chgo
    slightly off topic, sorry
    P
    There will at some rpm always be a rocking couple imbalance. Frequently it is around 4,000 to 4,200 rpm. Perfect carb synchronization won't make it go away.
    Interesting, Paul. After a number of years of riding my '82 R100, i "discovered"that there was a real sweet spot right at 4200. I've kept thinking there was something out of whack because my 2000 R1100RT wouldn't do the same, and was, in fact, rough at 4000-4200.
    We might as well walk. ~ Adam Guettel The Light In The Piazza
    used to own: 1982 R100T, 1984 R65, 1986K75C, 1997 R1100RT, R850R, K75S, 1978 R100RS... what was I thinking?
  11. #26
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    +1 on the Harmonizer.
    I have had sticks (still do but rarely use) , Twin Max, and finally the Harmonizer.
    I would never go back, an easy to use, well designed product. Love the rpm feature!
    Ufda happens..........
  12. #27
    Nov 2007
    The power produced on the sides needs to match. Since both injectors fire at the same time they need to be matched before you do anything else.
    Most major cities have someone that can clean injectors using a machine. Before cleaning my flowed 1% different, after it was not measurable on the machine cylinders. Mine is a little smoother. Not much, just a little.
    Then you need to clean the intake. I used sprays for this.
    Then I did a water torture combustion cleaning.
    change oil, set valves, new plugs, it was wonderful for about 2K miles.
    Our gas does not burn that clean. Some vibration is the nature of the beast.
    Personally on my bike, Bosch 4417 plugs do pretty good for more miles than anything.
    Rod
  13. #28
    Bluenoser
    Lethbridge Alberta
    I've had mercury sticks in the past and they worked but you had to be careful to not suck the mercury into the engine. Also other issues with breakage of the glass rods etc.
    I now use a Carbtune and it works fine, with no issues adjusting any engine with 1 to 4carbs/throttle bodies. To tame down the fluctuations in the sticks you have to use the restrictors in the lines, that's why ordinary vacuum gauges don't work, too much movement in the needles.
    My vote goes with the Morgan Carbtune because it will do so many different types of carb/efi engines. As long as they have a vacuum port you can use it.
    2013 DL650
  14. #29
    Apr 2012
    Heart Of Dixie!
    So, to be clear, even restricting the vac guages won't reduce needle movement to acceptable levels?
    I made\use a clear tubing version and interested in something more portable & has other uses besides balancing oilheads.
  15. #30
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
