Results 1 to 14 of 14
Thread: '04 R1150RT - Speedo
Hybrid View
    Aug 2005
    Charlotte, NC
    not working!
    And yes, i have replaced the cable. Anyone else ever had this issue? Is it something that can be repaired by one of the esteemed vendors? The last thing that i want to do is to have to buy a new one.
    Thank you,
    sdc
    Enjoying the ride, but always on the alert for a rally.......
    Registered User pettynerd's Avatar
    Oct 2008
    Menomonie, WI
    I had the same thing on my 04 RT, turned out to be the little plastic ring inside the speedo hub, my receipt says it was the Drive Ring. I do have an extra speedo for cheap if it's needed.
    Aug 2005
    Charlotte, NC
    Hey Petty
    were you able to get yours repaired? or did you have to replace with a new/used one?
    TIA
    Oct 2008
    Menomonie, WI
    They (MAX NH) were able to reajust the existing one, cost like $25
    Speedo
    Have you changed the tire?
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Check out the speedo drive and the drive washer item #7. Typically that is where the problem usually is. The tabs get bent back if the wheel hub is not positioned correctly upon replacement of the front wheel. Fixed a few now.
    http://www.maxbmwmotorcycles.com/fic...png?v=08102012
    Ufda happens..........
    Quote Originally Posted by 94aero View Post
    Oh, my...... I'm so happy we came to the same conclusion!
    R1150RT Speedo
    Thank Heaven for PGlaves!
