Results 1 to 15 of 16
Thread: 1100rt spark plug question
Hybrid View
    Finally found the Autolite 3923 plugs after ck'g Autozone and O'reillys at Pep Boys.
    Got the double platinum for longer life.
    Question is on the gap. With the stock plugs, dual prong it's only .031, but the Autolites are about .044 out of the box. For you guys who have installed these, did you leave that gap or change it?
    Tks.
    I'd go .035 to .040
    Florida & Massachusetts
    Mine came the same way. I don't know if it is best but I try to have the face of the tang parallel to the top of the center electrode. Given the amount of movement needed I found that difficult, one plug needed a slight compound bend, the other plug ended up with the ground extended well beyond the center electrode. I used them but didn't like what I went through.
    I use .035".
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Gap is determined somewhat by what the ignition system can crank out (along with fuel mix, compression, etc.). Cars' ignitions are historically much more robust than bikes'. If you can't reliably and repeatedly light the fires, it ain't gonna run right.
    Been a while, but I recall setting mine to .032 with zero issues, and let 'em wear - which they did quite slowly, and better than the factory Bosches (which I've never had "fine running" with anyway).
    Note that on some auto plugs, the manufacturer clearly intends that the gap is NOT to be changed - not only is the ground electrode Quite stiff, but it can be really easy to crack the center porcelain.
    Vancouver, B.C. Canada
    I'd go .035 to .040
    Hi Paul, I am curious on why the larger than spec gap to start off with a new plug.
    BMW factory manual states 0.8mm (0.0315) to a max of 1.0mm (0.039) so 0.035 is right in the middle.
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    Possibly due to the fact that it's an electronic ignition?
    -Albert Eienstein
    Not sure I understand. It was electronic when BMW recommended a smaller gap.
    My question for Paul was why go larger on a new plug.
    Crisper spark. Voltage builds to jump the gap. Larger spark too.
