Results 1 to 10 of 10
Thread: Garmin MicroSD Card
    Aug 2004
    Walnut Creek, CA
    Garmin MicroSD Card
    Those with a Garmin, I have question. On Garmin's website, they indicate a MicroSD card with adaptor. If you need to add a MicroSD card, do you have to purchase it through Garmin? Or, can you purchase an MicroSD card from the local electronic store.
    edit: FYI, this is for a Nuvi 1390 in my car.
    Jeff in W.C.
    Registered User arthurdent's Avatar
    Central Nebraska
    I bought some 4gb cards for digital cameras at school and had an extra. I put the extra into my 60csx and it works fine. SD is SD.
    Colorado Springs, CO
    Some older Garmins do not accept microSD"HC" cards. "HC" (high capacity) cards start at 4GB up to 32GB.
    Try to get a faster/the fastest card with a higher speed class rating. This makes find/search and map repaints faster.
    /Guenther
    Braintree, MA
    Garmin says one thing, but real world is different. I've been using 16GB class 10 cards in my 660 and 665 since I bought the devices. No issues.
    https://support.garmin.com/support/s...00000000000%7D
    -Tom (KA1TOX)
    Mar 2012
    Las Vegas
    Bought one to load Mexico maps at Best Buy. Worked fine.
    Registered User AKsuited's Avatar
    Jul 2009
    New York State
    I bought mine at Walmart. Works fine.
    Harry
    Aug 2004
    Walnut Creek, CA
    Thanks everyone. I was a bit confused when it said "and adapator." I was wondering what the adaptor could be for, but it sounds like it's no bid deal
    Jeff in W.C.
    I believe the adapter allows the 'micro' to be used as a regular SD. Simply slide the micro into the adapter. This allows interface with most card readers.
    Gear Up and Ride Safe
    Jim Rogers
    2010 R12GSA aka Heidi
    Yorktown, Va
    Sheboygan, WI
    Thumbs up
    Quote Originally Posted by AKsuited View Post
    Harry
    Same here - no problems.
    Quote Originally Posted by Jim Rogers View Post
    Also allows you to transfer information (routes, music,favorites) between GPSs that use standard SD cards (Zumo 450, 550, etc.) and GPSs that use Micro SD cards (Zumo 660, 665, etc). My suggestion is to always buy a Micro SD card with adapter REGARDLESS of what your GPS uses. That way you can always share and receive info from other sources regardless of card size.
