Results 1 to 8 of 8
Thread: 2010 RT and Odessey PC680
    Dave Nicholls 105258's Avatar
    Mar 2004
    Teulon Manitoba Canada
    Anyone put a PC680 in a RT of my vintage. My battery is toast and need a replacement.
    Dave Nicholls
    Teulon Manitoba - Canada
    2010 1200RT
    Nov 2011
    Central Ohio
    Most owners of 1210 models use a buggy whip to get their transportation moving...
    The PC680 works great in my 2006 R1200RT.
    Larry
    2006 R1200RT
    Spring Lake NJ, USA
    Quote Originally Posted by lkraus View Post
    I've corrected the year.. I tend to do things like that. I think there is a term for it.. (getting old..)
    Nov 2009
    Kirkwood, Missouri
    I just put a PC680-P in my 2009 RT it has 220 CCA verses 170 CCA in a PC680 and it works great. You have to install mounting brackets for the cables ,that are included, a simple operation.
    Registered User bmwed's Avatar
    Mississauga Ont, Canada
    Can I charge the PC-680 with the BMW canbus charger, or would I need to get a specific one for that battery.
    Ed
    Nov 2011
    Central Ohio
    Your current charger works just fine as a tender to keep the battery topped off. If you somehow completely discharge the battery, you might need a charger with a higher charging voltage (14.4-15V) to bring the battery back to life. More info than you would ever need is on the Odyssey web site. Check out the owners manual. If you have OCD tendencies, try the technical manual.
    One of the Odyssey advantages is that has an extremely low self discharge rate. If your bike sits unused for months, the battery can simply be disconnected (to remove parasitic loads like the clock) and left without a tender.
    Larry
    2006 R1200RT
    Odyssey says that the PC 680 needs higher amperage for charging initially and if discharged. The normal rule of thumb comes out between 1 and two amps. Odyssey (in the paperwork that came with my PC680) says to charge at 6 amps to 8 amps. They didn't mention voltage on that paperwork.
    I have a "big" charger with three settings: 2 amps, 8 amps, 12 amps. I use the 8 amp setting on the PC680. I use Battery Tender Juniors on other batteries/bikes.
    Nov 2011
    Central Ohio
    I stand corrected. (again. maybe I should just shut up)
    For some reason, when I bought my PC-680 I got the idea that my none of my chargers would work if it was completely dead. Re-reading the manual and the technical manual proves this wrong. My 10 amp automotive charger would work, using the deep cycle option. The technical manual shows a minimum recommended charge amperage of 6 amps and lists charging times for up to 20 amps. They recommend an additional 6-8 hours on a 2A trickle charger after the fast charge.
    Larry
    2006 R1200RT
