Results 1 to 15 of 25
Thread: Tire Pumps?
    Aug 2012
    Lenexa, KS
    Tire Pumps?
    Anybody have any recommendations on tire pumps (manual or powered). Just got a new RT in September and am trying to decide what to buy for a touring bike like the RT. Is it best to carry a manual pump in the saddle bag?
    Watch This!!! junkjohn's Avatar
    Feb 2010
    Cape Cod, MA
    www.advdesigns.com Has a micro tire pump and plug kit. I have used the pump about 6 times and for its size I am amazed with it. I also carry stop&go plug kit with co2 cylinders.
    John Simonds
    2008 R 1200 GSA
    1975 Norton Commando 850 Roadster Mk 3
    If it ain"t broke... fix it till it is.
    Apr 2006
    Used my Slime pump many times, even put out enough pressure to seat the beads on a pair of tires I changed on the road. Look for sales at the local auto parts chains, you can get one for sub $20
    http://www.amazon.com/Slime-40001-Mo.../dp/B000ET9SB4
    2010 F800GS Full Ohlins package, '04 R1100S Replika
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Tuscany and Central Italy 2010
    All-round Motorcyclist MarkM's Avatar
    Dec 2010
    St. Louis
    +1 on the Slime pump.
    Mark M, St. Louis, '13 R1200GS
    Administrator 20774's Avatar
    FYI...the owner has an R1200RT...thought that might make a difference! He said new RT, so I guess that's pretty clear to some people...not me!!
    Mar 2011
    Lawrenceville,ga
    I also have a Slime pump. I have used for about 2 years and still works great. You will need the BMW cigarette lighter adapter to use on the RT, but I use it on my 06
    R12RT with no problems.
    Sheboygan, WI
    Smile
    Quote Originally Posted by dtrott View Post
    CyclePump @ $99.00
    Apr 2012
    Maryland
    Quote Originally Posted by pffog View Post
    Yup, this works great. I ran an SAE pigtail to the battery to power it and for the battery tender.
    Braintree, MA
    There's a deal on a Slime pump at True Value going on now. $15 pump, $15 rebate.
    The True Value I found mine at wanted $19.95, but it;s still a good deal.
    -Tom (KA1TOX)
    Braintree, MA
    Quote Originally Posted by Greenwald View Post
    CyclePump @ $99.00
    Keep your eye on the lighter plug wiring. The screws that tie the wires down like to come loose, especially if you like bumpy roads. Open it up and take a peek. I soldered mine last weekend, always seemed to fail at the exact time I wanted to use it.
    -Tom (KA1TOX)
    jeepinbanditrider
    Go to Wal Mart in the back. 12V pump back there should be just north of 10 bucks. When it breaks, if it ever does I have one that is pushing a decade old, you toss it and get a new one.
    Feb 2008
    Savannah, GA
    I have the Slime pump and it doesn't work very good. Best I could get out of it was 24 psi. Go with a hand pump.
    Eastern KY
    Quote Originally Posted by MarkM View Post
    FWIW, go to a Slime website as there are more than one design-you decide which is best cause I have no idea. Also check out Meijer's in automotive for a cheapo pump.
    Sheboygan, WI
    Smile
    Quote Originally Posted by tommcgee View Post
    Thanks for the 'heads-up' but I prefer to use the alligator clips for direct hook-up to the battery terminals when inflating a tire.
    Pump is expedition-quality ... works great!
    Pumps?...
    Let's think this thru..... Ok, I have a flat, turn off the bike, take my gear off, repair flat, start bike and power up the electric pump, tire fills, turn off bike to put stuff away and put on gear. Done right?
    Get on the bike and try to start it..... It clicks..... The pump pulled more power than the charging system puts out at idle....
    Not sure how I know this.. Ok, I'm not telling.
    Keep compressed air canisters instead of the pump. Why risk two problems when you have just one..
    My $.02.
