Results 1 to 11 of 11
Thread: High Frequency Vibration
    Fire Don't Burn Motor unit 7's Avatar
    Nov 2006
    Leamington, Ontario, Canada
    Question High Frequency Vibration
    It would seem that I have a high speed 70 mph high, frequency vibration in my 2004 R1150 RT-P with 120,000 miles on it. The tires are new and I have micro beads for balancing which I have used before with on problems, the rims are also good.
    I replaced the front wheel bearings as I thought that was the problem. as it seemed to only be felt from the handle bars, but with that replaced it does seem to be the rear where it is.
    I now think that it could be the bearings in the final drive starting to go any one else have any ideas on this? drive shaft, splines, ETC.
    #13338 PGlaves's Avatar
    I would personally start with balancing the wheels/tires. Then I would move on to less likely culprits if that failed.
    Next suspect would be the universal joints in the driveshaft.
    the Wizard of Oz 26667's Avatar
    Jul 2006
    NW suburban chgo
    Fwiw
    I had similar on my 2000 RT and after a couple weeks in the shop, lots of looking at various components, different guys riding it, nothing. Put in a dose of Techron and it's been fine ever since.
    Hope it's as EZ for you
    PS Seafoam seemed to have no noticeable effect whatsoever
    We might as well walk. ~ Adam Guettel The Light In The Piazza
    used to own: 1982 R100T, 1984 R65, 1986K75C, 1997 R1100RT, R850R, K75S, 1978 R100RS... what was I thinking?
    Nov 2006
    vibration
    Thanks Paul and 26667
    I think I will try the tire balancing sounds like there could be a problem with the Micro bead installation as the shop had not done it before and they could have lost some of them instead of them going in the tire.
    That would do the trick and give the type of vibration I am getting, did not have the problem before the tires were put on, but also I was running at a slower speed for a fair while before getting up to the higher highway speeds.
    I have to say that I have had Micro Beads on three bikes and never had this before, in fact I have had a superior ride with them but they would not work right if the right amount was not put in just like if there was too much or to little weights on the tire.
    Apr 2005
    Hopefully it is something simple like that. As a note, you can check the rear end pretty easily. Put it on the centerstand and spin the rear wheel by hand. It should spin smoothly. If it's "grindy" your big bearing may be going bad. If it's "notchy" one of th u-joints in the driveshaft may be going bad.
    That being said, I would be looking for a used driveshaft (new if you can spare $700) for that bike. There have been several instances of driveshafts letting go at around 100K miles on those bikes. It can be pretty spectacular, so you'd like to avoid it if possible.
    Professional Slacker
    Deland, Florida
    Vibration
    I realize this is an older thread, but I wanted to re-open the issue on drive shaft orientation and balance.
    I just replaced the entire clutch assembly on a '96 R1100GS with 115,000 miles. The bike ran silk smooth prior to the work. I remember being very careful to orient the clutch components and the "flywheel". However, I failed to orient the drive shaft. It simply slipped my attention.
    Now, I am experiencing the "70 MPH" buzz in the feet and hands. Wheels and tires do not seem to be the problem.
    Could someone remind me the proper "orientation" of the shaft and the U-joints?
    Vancouver, B.C. Canada
    Quote Originally Posted by rowens816 View Post
    The yokes need to be lined up.
    Here's a photo of a BMW drive shaft correctly phased
    Courtesy of StepToe over on the ADV site:
    Paul Glaves posted a great image of correct vs. incorrect drive shaft phasing but I cannot seem to search my way there this morning. Need to bone up on site googling again.
    Deland, Florida
    Thanks, Wanderer. Pictures from the rebuild show that I did it correctly. Whew!
    However, the vibration exists. I'll have to continue the search for cause.
    If the engine is running smoothly as Paul mentioned above it's best to start with the tires and wheels and work from there.
    I once had a hard to trace vibration at speed problem years ago that caused similar symptoms and it turned out to be belts in the tire separating inside the tire. But that is about as rare as can be.
    May 2011
    Maryland.
    I am surprised that nobody mentioned the handlebars. For example, I purchased some aluminum handlebar ends from wunderlich.
    The handle bar ends are much lighter than the factory one and this raised a red flag to me when I installed them. It seems heavy handlebar ends help reduce vibration from the motor.
    Did you change your bar ends ?
    http://www.wunderlichamerica.com/mot...66145-185.html
