Results 1 to 15 of 25
Thread: Heated Grip Interchange K1-K75
    Registered User argent brick's Avatar
    Aug 2012
    Wine Country, Northern California
    Is there any reason why I can't use K1 heated grips on my K75?
    Lynn
    MOA #57883
    Current Ride: 1995 K75 Standard
    Past: 1978 Yamaha XS 750, 1976 BMW R60/6
    Northern Front Range, CO
    along as the wiring is of sufficient lenght, should be no reason you can't.
    compare pns for each, see if different.
    Ride Safe, Ride Lots
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    K1s use barend weights, K75s do not. K1 grips are open at the end to accomodate the weights. K75 grips are closed on the end. You will need to come up with something to plug the ends. Otherwise, should work.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Aug 2012
    Thanks guys. It is just a thought for when the grips I have now bite the dust. There are so many things more important to do on my bike that it is not funny. New grips are at the bottom of the list.
    Lynn
    MOA #57883
    Sep 2012
    San Ramon, CA
    Lynn,
    Why not use K75 heated grips on your K75?
    David Sword
    Aug 2012
    That is what I have now, but I find the K1 grips more comfortable. When the time comes, I will probably just put another pair on like I already have.
    What I would really like to find is some way to keep the wind off of my hands.
    Lynn
    MOA #57883
    Slipster Slipster's Avatar
    Jun 2012
    Broken Arrow, OK
    The late "airhead" R80GS handguards worked out real nice on my K75S. Just a little modification to correctly cover the brake fluid reservoir.
    Expect The Unexpected
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Quote Originally Posted by Slipster View Post
    OR you could buy the correct ones that are made for the K75 and R100GS.
    71 60 2 315 870 SET: RETROFIT KIT, HAND GUARD, BLACK $41.05
    Mine, Hers, Spare
    Aug 2012
    Lee, You know this forum just would not be the same without your knowledge and support. Thanks.
    Lynn
    MOA #57883
    Jun 2012
    Broken Arrow, OK
    That's the pair that I have. Still had to use a little black tape over the reservoir and around the hand gaurd.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Then there is another problem with your hand guards or your bike. They fit K75s perfectly. I've had them on my bikes (sometimes). I think I've got them on one of my bikes now. I'll post a picture after I get back from the movies.
    Mine, Hers, Spare
    Sep 2007
    I'm a bit late, but the K1's throttle tube is very different than the K75. You can change the grips-even on heated grips-with some careful work.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Mine, Hers, Spare
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Mine, Hers, Spare
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Mine, Hers, Spare
