Results 1 to 4 of 4
Thread: Paralever Drive Shaft - new or repair
    Colorado Springs, CO
    Time to replace the drive shaft on my R100GS ... again. Besides buying an OEM ($713 at the dealer) there are a few other options.
    Has someone used a "repaired" drive shaft?
    I have only found Bruno's in Canada who does repairs. Any other shop?
    Has somone used the rebuildable one that Ted Porters beemershop sells for $580?
    Just for the statistics:
    1st shaft lasted 60 tmi, 2nd one lasted 72 tmi and cost $415 in 2001 at the dealer.
    Thanks,
    Guenther
    Here's what I found with a forum search:
    http://forums.bmwmoa.org/showthread.php?t=58762&
    I think I saw mention of a Medford, OR, shop...proabably Hansen's BMW.
    Thanks Kurt for the link! (Lazy me could have found it myself)
    Following some links off of that brought up Henderson Precision in California:
    http://www.advrider.com/forums/showt...ight=hendersen
    I was thinking of only having the U-joints replaced. By following the discussions it was mentioned that the damper usually needs to be re-worked as well. Hurried to the workshop and sure enough, my damper has twisted by ca. 15 degrees and needs to be repacked as well.
    /Guenther
    Bluenoser
    Lethbridge Alberta
    Quote Originally Posted by Guenther View Post
    Thanks,
    Guenther
    For just the u joint on the drive shaft. I asked Bruno for a quote on replacing the u joint on my SWB driveshaft and he quoted $200. He pins the new u joint in the same way the factory does and doesn't spot weld them like some I've seen.
    For your info and help in finding a source.
    1999 R1100s
