Results 1 to 8 of 8
Thread: 2003 R1150RT Warning Light
    2003 R1150RT Triangle warning lite comes on continuously when ignition turned on and stays on. Problem occurred at about 93000 miles and is still there everytime for about 2000 miles. ABS lite works normal. Brakes seem ok, but haven't had to use an emergency stop.
    Bill Lumberg 175781's Avatar
    Dec 2011
    On mine (2004R1150RT) that means the brake light is out or is about to go out. It happened to me frequently. I tried going to OEM bulbs (or the bulbs they sell). Didn't make much difference. I started thinking about all the systems or wiring that could be faulty. Then I slowed down and cleaned the brake light contacts with alcohol and tweaked the spring. No problems since.
    R75/6, 2004 R1150RTA.
    R1150RT Stop Lite out
    Thank you. I had a Wal Mart boat trlr LED lite installed below my license plate and it's brake lite was so bright it looked like the main brake lite was working.
    Dec 2011
    Keep in mind, you can blow a brake light, and the bike will increase voltage to the tailight when the brake lever is pulled to compensate. This, too, can camoflage a blown taillight.
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    Quote Originally Posted by 175781 View Post
    I know this is true on the R1200 bikes. I didn't think it was true on the 1150 non-canbus bikes as described in the original post.
    Registered User kioolt's Avatar
    Maryland
    According to my 04R1150RT Owners manual the brake will compensate for a blown tail light by lighting up at partial intensity. There is no mention about the tail light compensating for the brake light.
    2004 R1150RT 155,600 miles , 1991 K100LT 128,400 miles, 1982 R100RT 106,900 miles
    Total 390,900 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Dec 2011
    That is correct. I stated it backwards.
    Apr 2005
    Walland, TN
    On my '04 1150 GS the brake warning light came on and I looked at both the rear light and bulb-everything appeared fine. The warning light went off for a brief time then re-illuminated. The second time I checked the the bulb it was obviously blown. I believe the system senses an increase in resistance before the bulb actually blows.
    2004 R 1150 GS
