Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
Thread: Feds probe BMW motorcycles for fuel leak problems
    From today's Columbus, OH, Dispatch newspaper:
    Federal safety regulators are investigating older BMW R-Series motorcycles for gasoline leaks that could cause fires.
    The probe affects about 24,000 motorcycles from the 2005 through 2008 model years sold in the U.S.
    The National Highway Traffic Safety Administration says the housing around the fuel pump can crack and leak gasoline. No fires or injuries have been reported, but the safety agency has received 28 complaints from owners of the bikes. At least two owners say that gas soaked their pant legs.
    Investigators will check into how often the leaks happen and determine if a recall is necessary.
    1969 Triumph Bonneville T120R, 1972 Commando 750, 1974 Vespa Rally 200, 1974 Commando 850, 1975 Commando 850, 2010 Triumph T100 w/sidecar, 2011 BMW R1200RT, 2013 Honda CB1100
    bikerboy108
    Nov 2006
    North Jersey
    How about ABS!!!!!!!
    Nov 2005
    Fairfax, VA
    This is the hexhead fuel pump assembly cover fitting cracking issue ("fixed" in later camheads, such as my '12 R12RT by a different configuration of the cover).
    Mark Neblett
    Fairfax, VA
    #32806
    Quote Originally Posted by zenduddhist View Post
    ... the housing around the fuel pump can crack and leak gasoline. No fires or injuries have been reported, but the safety agency has received 28 complaints from owners of the bikes. At least two owners say that gas soaked their pant legs.
    Good! I was one of those 28 people who took the time to file a report.
    This recently happened to me on my HP2e and thanks to help received here and on ADVrider, I was able to avoid having to buy a **$550 freakin' dollar*** part to fix it.
    The cracks are caused by an incorrect application of tapered threads, and BMW should replace this part on all affected models. I had to ride my bike out of the woods in TN and 150 miles back to Atlanta with gas shooting out like a squirt gun because I had no other way to get home.
    Curiously, the replacement part had a metal ring affixed to the flange to keep the plastic from cracking. Nothing like a band-aid fix, eh?
    Beemer Boneyard sells a CNC-cut part for $35 that squeezes the flange to seal the cracks, and this along with some Yamabond case sealant and new metal quick disconnects has solved the problem. Sorta... this is basically jerry-rigged and I'd rather not be riding my bike with a fix like this, but $550 just isn't in the picture at this point in time.
    Looking back through the thread on ADVrider, the part in question has increased in price from about $250 to $550 over the period of just two years.
    Ian
    __________________________________________________ ________________________________
    '67 Trail 90 || '86 R80 G/SPD+ || '97 F650ST || '00 1150 GS || '06 HP2e || '07 Xchallenge || '14 Grom
    Nov 2005
    Calgary, Alberta
    Ian: could you post a link to the ADVrider thread?
    Is this the fuel system componenet that sits in the well at the left front of the tank?
    I had the one on my bike inspected and sealed by Anderwerks as part of its out of province inspection last spring.
    Rinty
    Debbie's Servant Lee's Avatar
    SW Iowa
    The National Highway Traffic Safety Administration says the housing around the fuel pump can crack and leak gasoline. .
    The same thing happens on the Slant four K bikes, plus the plastic quick disconnect can break.
    Lee
    2016 R1200RS
    MOA # 30878
    Riding where it's hot! AZ-J's Avatar
    Mar 2007
    Scottsdale, AZ
    I had fuel all over my left leg from a cracked fuel pump recently on my 2007 R1200S.
    I did not know this could be reported, or I'd be #29!
    My bike shown here
    Jordan M, MOA #24434
    My Blog
    Richmond, Va
    I had to buy the $500 + piece of plastic for my '06 R1200GS Adventure before the clamp solution came out. I am considering adding the clamp as preventive maintenance.
    I did not file a report on it, but it sounds like I should have.
    Roy F
    Richmond, VA
    Dec 2005
    East Texas
    Go ahead and file a report. The more info on the record, the better.
    Diamondhead, MS
    Quote Originally Posted by chicota View Post
    Right!
    File the reports. This is not over.
    Quote Originally Posted by rinty View Post
    Rinty - here you go:
    http://www.advrider.com/forums/showthread.php?t=711467
    Yes, on the R1200GS. On my HP2e the plate is on the top. Various models put it various places.
    It sure is worth it. I was surprised at how quickly the problem appeared.
    Ian
    Mar 2007
    Scottsdale, AZ
    Where?
    My bike shown here
    My Blog
    Diamondhead, MS
    Quote Originally Posted by AZ-J View Post
    Where?
    Duh !
    Go back and read the first post. Its the National Highway Traffic Safety Administration.
    You can Google it.
    Mar 2007
    Scottsdale, AZ
    I used Google to find the NHTSA but did not find where to report.
    My bike shown here
    My Blog
    Mar 2007
    Scottsdale, AZ
    Report filed!
    My bike shown here
    My Blog
