Results 1 to 9 of 9
Thread: 98 R1100RT heater vents
    Ash Grove, MO
    Lightbulb 98 R1100RT heater vents
    It's amazing what you can find out by reading the owner's manual! I just figured that the extra little grills on the dash next to the speaker grills were 'extra' speaker openings. Then I find out I can 'turn on the hand heaters' with the little levers inside! The heat is actually effective! Rode with out gloves and could feel the warmth on my fingers, and the control levers were warm to the touch!
    Now, if I can just rig up little fans in the duct work so they work at city speeds!
    Mike Davis
    1985 K100RT
    1998 R1100RT
    They weren't popular enough to be carried over to the R1200RT, however.
    May 2011
    I have an 00 R1100Rt. Those vents are great at 30 mph around 45*f. When colder, the thermostat on the bike does not open and there is no warm air. Going faster and the warm air gets diluted before it reaches my hands.
    Kinda useless for me.
    Good idea that did not work for me.
    David
    Planet Earth
    The concept was a great one. But, the usability is not so good. I have heated grips, which are awesome, so the heated vents are of limited value to me. I wish they would have done this with the early K bikes. BMW just cannot seem to get heat pointed in the right direction. The concept was done on the wrong bike.
    No longer a member here
    I have a 99 R1100RT. I like the heated vents. I don't ride, when it is below 50 degrees.....
    143439 bobr9's Avatar
    Jun 2012
    Clarkesville, GA
    Quote Originally Posted by EMSimon View Post
    I have a 99 as well. For the life of me I can not find the lever to open the vents. Manual seems to indicate inside the glove box, but not on my bike. Were they an option?
    May 2012
    Escondido
    I just reach down by the front forks. There is a small metal lever on each side. I also found out about them through the manual. I turned them off when it was so hot this summer. It's time to turn them back on now.
    2000 R1100RT-P
    Jul 2006
    Fraser, CO, USA
    Yep, two silver bars in the opening between the instruments and the gas tank. I never can remember which way is open or closed, so I labeled them with a paint marker. I agree that when its cold (all relative), they don't seem to do much, but at moderate temps, they are noticeable.
    Conrad Long
    MOA # 82902
    '94 R1100RSA
    '96 R1100RT
    Apr 2007
    Nacogdoches, TX
    Nor to the R1150RT.
    Probably the idea was overtaken by the very effective heated grips, and dropping them was a way to lower build cost.
    '04 Silver R1150RT "Big Oel"
    '76 Red R65/6
    Looking for Ed Sanders' Truck Stop!
