Page 1 of 8 1 2 3 ... LastLast
Results 1 to 15 of 117
Thread: The Wethead has arrived....
    Big pig!
    Ian
    __________________________________________________ ________________________________
    '67 Trail 90 || '86 R80 G/SPD+ || '97 F650ST || '00 1150 GS || '06 HP2e || '07 Xchallenge || '14 Grom
    Norm Norms 427's Avatar
    Spokane, WA
    I like it.
    Looks like the cylinders still have cooling fins.
    Thanks for posting.
    Now: '12 R1200RT Midnight Blue Metallic / '11 Ural Patrol 2WD ridden to Alaska / '09 KLR 650 / '05 HD Heritage Softail / '08 Harley Sportster 1200C / '85 Yamaha VMax bought new. I wasn't ready to say goodbye: www.shaunlunt.typepad.com
    From the Press Kit
    An overview of highlights of the new BMW R 1200 GS.
    Completely newly designed engine for top-level riding dynamics within the travel enduro segment.
    Capacity 1170 cc, rated output 92 kW (125 bhp) at 7700 rpm and a maximum torque of 125 Nm at 6500 rpm.
    Cylinder heads with vertical through-flow for increased efficiency and performance.
    Compact air/water cooling for optimum heat management.
    Basic engine with compact, light and yet rigidity-optimised crankshaft.
    Vertically separated case in open deck construction.
    6-speed gearbox integrated in engine housing, including wet clutch with anti-hopping function and reduced lever operation force.
    New intake system for optimum output and torque with 52 mm throttle valve diameter.
    E-gas for improved ridability, running smoothness and special functions.
    Innovative exhaust gas system with electronically controlled exhaust flap for optimum performance characteristics and an earthy boxer sound.
    Freely selectable riding modes ǣRain, ǣRoad, ǣDynamic, ǣEnduro and ǣEnduro Pro with three different electromotive throttle actuator settings in conjunction with ASC (Automatic Stability Control), ABS and ASC settings for off-road riding as well as different mode-specific Dynamic ESA settings (option ex works).
    New suspension with torsionally stiff tubular steel bridge frame and bolt-on rear frame.
    Optimised lightweight cardan shaft drive now running on the left-hand side.
    Newly developed and optimised Telelever at front and EVO Paralever at rear for an even more precise ride feel.
    Refined master chassis geometry data and long swingarm for excellent traction.
    Optimised seating width and position, and adjustable handlebars for even greater comfort.
    Optimised ground reach for rider (inner leg length).
    Tyre/wheel dimensions of 120/70 R19 at front and 170/60 R17 at rear as a world first, tailored specially to the R 1200 GS.
    Revised BMW Motorrad brake system with radially mounted Brembo Monobloc brake calipers at front and 2-piston floating caliper with enlarged brake disc at rear (? 276mm, previously 265mm).
    BMW Motorrad Integral ABS as standard.
    Semiactive suspension Dynamic ESA (ex works option).
    Main headlight with optimised light efficiency and LED daytime running light (ex works option).
    Worlds first motorcycle with LED main headlight featuring integrated daytime running light (ex works option).
    New vehicle electrical system with partitioning of functions.
    Extended electric switch units.
    Electronic cruise control (ex works option).
    Preparation for navigation unit with Multi-Controller to operate the
    BMW Motorrad Navigator IV (ex works option).
    Windshield with one-hand operation for excellent wind and weather protection.
    Seat with multiple adjustment functions for perfect ergonomics.
    Number plate carriers quick to dismount for off-road riding.
    Increased ground clearance (+ 8 mm)
    New instrument cluster with on-board computer as standard. PRO on-board computer as an option.
    Four main paint finishes to choose from:
    Alpine White, Racing Red, Blue Fire and Thunder Grey Metallic
    I especially like the position of the airbox. This bike should do much deeper water crossings.
    Ian
    Central Illinois
    I like it.
    I didn't see the weight posted. Lighter? Heavier?
    I was hoping for more than a gain of 15HP though.
    Cruise control !!!!
    Howard Edwards
    2014 Road King; 1975 R75/6
    Am I insane or are these of the old motors? The pics came in the new R12GS press package....
    Still Wondering mika's Avatar
    Aug 2004
    Fly Over Land
    Yes you are, and yes they do look like the old motor pics. I have had trouble with my download file so can't comment further...on the pics at least.
    Pass the mustard and UP THE REVOLUTION!
    I think those last pics are of the old motors. 1200, 1150 & 1100.
    The new bike looks thinner.
    Looks like the clutch is on the front of the motor. Interesting! Or I am a complete idiot
    2012 R1200 GS Adventure
    Quote Originally Posted by Visian View Post
    Big pig!
    Ian
    And there's a Rhino in the background too!
    Planet Earth
    Looks like we need a new section on the forum for "Wetheads"?
