Results 1 to 6 of 6
Thread: R100GS rear final drive rubbing the hub
    Registered User arptra's Avatar
    Feb 2006
    Dallas Texas
    I just bought a 100gs and noticed the rear wheel hub is rubbing my final drive a little,, removed the wheel and everything seams ok. is there supposed to be a spacer there?
    Alan,,
    Dallas Texas
    74 R90S, 76 R90S, 95 R100GSPD, 08 R1200GSA
    Vancouver, B.C. Canada
    Tire size ?
    Feb 2006
    Dallas Texas
    130/80/17, I had a spacer I put om and it pulled it out,, bearings feel very good.
    Alan,,
    Dallas Texas
    I don't know what year or model 100gs you have but the tire size looks right. For the 87 to 90 100GS there is no spacer shown on the parts fiche. Suggest you take a look at the parts fiche to determine what is on your specific year and model to make sure though.
    Go here: http://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx
    Select your specific model and check the Wheels section. It's all in there. If all the right parts are there hopefully someone with more gs knowledge will chime in shortly.
    Feb 2006
    Dallas Texas
    it didnt show spacer on my 89 but I had some parts from a guy and he said it was for running a bigger tire. Any way it moved it out a fraction and is obviously all it needed,, lugs may not have been tight, I removed it with air.
    Alan,,
    Dallas Texas
    Glad you figured it out. Still a bit strange though because that is the right size tire.
