Results 1 to 12 of 12
Thread: Fairing light/1983 R100RS
    May 2004
    boise, idaho
    What are my bulb options for the light above the headlight on the RS fairing? The OEM bulb is dodgy on my bike and I'd opt for something brighter if I knew what it was...
    TIA
    Pismo Beach, CA
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Apr 2012
    Gilbert, AZ
    I believe he's talking about the 'eyebrow' light, not the headlight.
    2004 R1150RT
    BMW MOA 181289
    Pismo Beach, CA
    d'oh!
    It's a 4w bulb. I think I've seen LED replacements for it, but don't know if they put out anymore wattage.
    If it's "dodgy" maybe just replacing it will suffice.
    edit- 12v 35w halogen replacement. That's a huge jump in heat output to use in an enclosed housing.
    the base configuration is BAX9 if you add H6W it denotes "halogen, 6watts". Probably a much better replacement than 35w.
    12v 6w bayonet base from > http://www.thetoolboxshop.com/ab434-...ulb-9783-p.asp
    Xenon BAX9 1WHP (1 watt, high power) might "look" brighter.
    from > http://www.xenonrider.com/LED_lighting/BAX9_LED.shtml
    and is available in colors.
    Lew Morris
    1963 Dnepr
    don't expect that light to actually do much. its sufficient for illuminating the front of the bike when stopped on the side of the road, headlight off, but not much else.
    May 2004
    boise, idaho
    Thumbs up 1983 R100RS fairing light
    Thanks, that's exactly what I was hoping would be forthcoming. I'm going to fit an amber 1 watt LED in the fairing as a means of being more readily noticed by the oncoming cagers.
    blah blah blah squiffynimrod's Avatar
    Dec 2008
    Regina SK Canada
    Here's a great mod for that wimpy bulb. I bent the center contact of the base back slightly to allow the wires from the led set through. So this mod is entirely reversible back to stock with a pair of needle nose pliers.
    http://www.advrider.com/forums/showt...hlight=driving
    No pithy comments available at this time.
    Please check back later.
    May 2004
    boise, idaho
    1983 R100RS light
    I ordered the LED, but it turns out "it's no longer available." Time for plan B....
    Registered User richardak's Avatar
    Dec 2007
    Fairbanks, AK
    Quote Originally Posted by squiffynimrod View Post
    I really like this mod. I noticed that Amazon lists a bunch of similar lights and some of them give dimensions with drawings....
    1983 R100RT hacked w/Cozy Rocket My blog
    2012 Ural Patrol
    Airhead #10576
    MARKB635
    I used this one in amber. Around the same brightness as the incandescent, but a little less draw on the charging system.
    http://www.superbrightleds.com/morei...9-led-tower/9/
    South Carolina
    I removed the bulb from mine as it serves no purpose.
    AKA SNAPGADGET
    Pismo Beach, CA
    Well, as noted by bikerfish, it does,
    and especially if you live in European cities where street width is generally far narrower than here in the States. It's a "parking light".
    Lew Morris
    1963 Dnepr
