Results 1 to 7 of 7
Thread: Trailer-in-a-bag & K1200LT
    Jan 2012
    Hello everybody,
    I recently purchased a used Trailer-in-a-bag for use with my '02 K1200LT. Does anyone have experience securing this particular BMW on this trailer or any other trailer for that matter?
    For lateral stability it appears to me that the only suitable hook locations on the bike are on frame members under the seat and therein lies the problem for me. The come-along straps would wench themselves too tight against the body panels since those straps would be in a downward angle towards the trailers axle mounted tie-down points.
    I would love to hear other riders tips, experiences & successes when it comes to properly tying this machine down to a trailer.
    Thank you
    Jan 2005
    Grayling, MI
    Trailer woes
    Many shops and accessory catalogs offer pairs of strap loops that can be wrapped around handlebars and hard to get to frame rails to hook up tie-down straps.
    I would caution you to get help while finding out what works. I seem to get into trouble more often loading and unloading bikes then riding them.
    Wayne Koppa
    Grayling, MI
    #13338 PGlaves's Avatar
    Soft ties around the fork legs above the fork brace at the fender.
    Registered User johnbaker15's Avatar
    Sep 2011
    Chelmsford, Mass
    BMW recommends tying the front forks and the subframe under the rear bags. If you want to buy new handel bars use them as tie points, because they will bend!
    I have use the recommended BMW tie point a few times and they worked fine. I also had the front wheel in a chock. HTH
    BMW 2005 K1200LT
    Suzuki 1979 GS1000E
    Jan 2012
    Great advice from everybody, thank you. Also, thanks to everyone for your quick replies.
    The handlebars were never in contention as an anchor point. My next step is to follow the advice given herein and learn more about the BMW recommended tie down points.
    Now I know what I'll be doing this weekend .... the tips are much appreciated!
    Nov 2005
    Fairfax, VA
    One other warning: Do not be tempted to remove the tip-over wing covers and use the bars as tie-down points.
    The wings are very strong in the upward direction (the tip-over direction), but have virtually no resistance to being pulled downward.
    It doesn't take much downward force to snap the rear tip-over bar mounting boss off the frame, at which point you are looking at $2500+ just for the replacement part (the entire main frame) -- unless you can find that rare welder that can (and even more, its willing to try) to weld the boss back on, on a cast Aluminum frame of unknown alloy composition.
    Mark Neblett
    Fairfax, VA
    #32806
    Apr 2009
    Huntersville N.C.
    Quote Originally Posted by mneblett View Post
    I have had good results welding the broken tabs back on the frame. I have done several of them so far & you can't tell it was ever repaired. It is about a $900 repair.
    Dave
    2004 Black LT
    2000 Canyon Red LT
