Results 1 to 11 of 11
Thread: 1200rt 2008 56k miles rear wheel bearings
    Ozzie Flyer
    Brisbane, Queensland, Australia
    Question 1200rt 2008 56k miles rear wheel bearings
    I am told by dealer mine are shot? Normal at this mileage? Big deal? Anything else to consider?$1k to replace in Australia.
    First issue for this bike.
    Best regards
    Paul
    regards
    Paul
    Ozzie Flyer
    BE KIND TO HUMANS... THEY BITE
    Aug 2010
    Calgary, AB. Canada
    Paul,
    That is odd as the bearings are sealed and should last a wee bit longer that quoted.
    What type of riding are you doing, highway or dirt/gravel. What are you carrying extra. Apologies for the silly questions, but sealed roller bearings typically don't wear out that fast. Something is missing here?
    Rick MacPherson
    1968 BSA Starfire, 1976 BMW R75/6, 1992 R100RT, 2009 R1200RT
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    Rear wheel bearings? Do you mean the final drive?
    My Motorrad
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
    Wilmington, NC
    Nothing else in the back that pricey so it sounds like we're talking FD here. Only other thing that pricey is the driveshaft with U joints.
    The mileage is earlier failure than some and more than a few failed earlier yet.
    OP- you can easily check this yourself. The rear wheel shake in two planes should not produce more than 1mm of movement as measured at the wheel. Also, if you remove the caliper so there is no brake drag, and pivot the FD down you can spin the drive disconnected with the wheel off. It should be dead smooth and not leaking.
    If there is play (some would say any but BMW allows u to 1mm), or if rotation is notchy or even if the drive is just leaking you probably need or will soon need rebuild or replacement of the FD. The big seal on it can leak without any other issues being present and is a fast and cheap repair but often it can also be a bad bearing causing a seal to die..
    Ozzie Flyer
    Hi
    Service mgr tells me crown bearing and needle bearing gone plus seals to replace
    Parts at $600 so labour at $400 = 3 hours work to pull apart and replace.
    Crown bearing $340 needle bearing $190 plus seals
    Parts seem ridiculous to me labour seems sort of ok.
    Regards
    Paul
    regards
    Paul
    Ozzie Flyer
    Wilmington, NC
    Its a typical price for a rebuild. If you want much cheaper you'll either need to find a used FD or do it yourself
    The reality of motorcycle final drives is that over a whole lot of miles (100K or more), all 3 types, chain. belt or shaft, are approximately equally expensive. Ratio of parts and labor and frequent of maintenance vary but costs come out similar..
    Ozzie Flyer
    Thanks guys
    regards
    Paul
    Ozzie Flyer
    Ozzie Flyer
    Quote Originally Posted by pch123 View Post
    Thanks guys
    Good news bike fixed. dealer discounted price by 50%.
    So now he has my attention and the new bike is looking to be around January.
    My faith in life has been renewed. Thanks for the advice.
    Regards
    Paul
    regards
    Paul
    Ozzie Flyer
    ".. pivot the final drive down.... disconnected..."
    Not understanding. My '02 has some slack at 63K and I need to check. Could you clarify?
    Quote Originally Posted by GKman View Post
    Your '02 is not a hexhead. Completely different rear-drive (you own a what?) Slack - play between the gears - is normal. Side to side movement of any shaft or roughness in turning a shaft indicate failed bearings.
    Nov 2005
    Calgary, Alberta
    Regards
    Paul
    Now you can celebrate by taking it for a brisk run up to Springbrook.
    Rinty
